IL 500+HP Turbo M3, 72k original miles, Showroom/Photoshoot Condition, Track Ready, FAST
1996 BMW M3
-72xxx miles on chassis, ~5k on rebuilt motor
-5-Speed Manual Transmission
-2 Door Coupe
-NEVER driven in snow/rain
-Weekend Summer toy ONLY
-Garage kept (with BMW e36 car cover)
-Non-smoker
-Rarely ever driven with more than 1 passenger; NEVER with more than 2 passengers (nobody sits behind me... I don't scoot my seat up for anybody!)
-No Food/Drinks EVER allowed in car, except for bottled water
-NEVER tracked/roadraced
Factory Options
-HK Premium Sound System
-6 Disc CD Changer
-Electric Power Sunroof
-Heated Leather Seats
-OEM Car Alarm
Exterior
-Cosmos Schwarz Metallic (Black) original paint in excellent condition
-OEM US spec headlights
-OEM Clear Euro BMW taillights
-Smoked side markers (side lights)
-Limo smoked front corner lights (still transparent with amber bulbs; lights up amber at night)
-Front bumper velocity splitters
-Fog light delete covers painted to match Cosmos Black
-Side moldings and side marker moldings painted to match Cosmos Black
-Front plate delete
-Kidney Grills painted to match Cosmos Black
-35% Legal Tint on rear 5 windows
Interior
-Manual Vaders (seats)
-Dove Grey leather interior
-3spoke Steering Wheel
-Gauges (Boost, A/F, Oil Psi, and Temp)
-Full OBC (On-Board Computer) Display
Engine
-s52 3.2L OBDII
-Rebuilt motor (approx. ~5k miles)
-Rebuilt (port & polished, 5angle valve job) head by Pete McHenry with all new guides, springs, valves; resurfaced face
-VAC Multi-Layered Steel (MLS) Head Gasket (0.070 stock thickness)
-ARP Head Studs
-CP Pistons 9.0:1 compression (High temp thermal coating by LO-KO Performance)
-New Rod Bearings & Bolts from VAC
-Stock BMW Forged Rods
-Underdrive Power Pulleys
-New OEM Motor Mounts (less than 5k miles)
-New Engine Gaskets from VAC Motorsports (less than 5k miles)
-New OEM Radiator (less than 5k miles)
-New OEM Thermostat & Waterpump (less than 5k miles)
-M50 Intake Manifold
-Custom Exhaust (No Cat)
-Walbro 255 High Flow Fuel Pump ***hard-wired to Battery
-Mass Air Sensor (3.5” HFM) provided by: Nick Glantzis
-42# Fuel Injectors provided by: Nick Glantzis
-New Oxygen Sensor replacement (less than 100 miles)
Turbo & Components
-Garrett T60-1 Turbo T3/T4 .83 turbine, .70ar compressor, stage III wheel
-Turbonetics T3 Turbo Manifold (High Temp Thermal Coated)
-Front Mount Intercooler
-38mm Greddy External Wastegate (9.6mm spring)
-Tial ByPass Valve
-Greddy Profec-B Spec-II Boost Controller
-VDO Gauges: Boost, Air/Fuel (AEM Wideband), Oil Pressure, Oil Temp
-Tuned by: Nick Glantzis (Technique Tuning.com)
Software changes include: (Increased engine rev limiter, Increased vehicle speed limiter, Remapped fuel and spark maps for custom mass air meter and larger injectors)
Transmission
-3.23Limited Slip Differential
-SPEC Stage 3 Clutch & Flywheel
-Rogue Transmission Mounts
-New Bosch Starter
-New Flex Disc/Guibo
-AA Differential Support Bracket
Suspension
-Eibach Springs & Sway Bars
-Bilstein Sport Shocks & Struts
-Motorsport X-brace
-Sway Bar reinforcement plates
-Ground Control rear shock mounts
-Ground Control Shims
-OEM rear trailing arm bushings
-New OEM Control Arms
-New OEM Tie Rods
Brakes
-Brembo Rotors
-Hawk HPS Pads
-Stainless Steel Brake Lines
-Brake Calibers painted semi-gloss black and Rotor Disc centers painted matte black
Wheels/Tires
-Fikse Mach V Wheels 17x8.5 on
Yokohama Advan Neova AD07 245/40/17
Less than 1k miles on tires (<11/32nds)
OR
-Replica Lightweight M3 Wheels 17x7.5 on
Yokohama AVS ES100s 225/45/17 (nearly bald)
Spare:
-Authentic Lightweight M3 Wheel 17x7.5 on
Michelin Pilot SX 225/45/17 (~10/32nds)
Additional Notes
-Motor is capable of pushing 21+psi. I have personally driven the car on 21psi with no issues at all and it is FAST! Though, the car is tuned to 15psi and is typically driven on 9psi on the street. This thing is FAST. I'm talking Z06 killer! With forged rods, low compression pistons, thick MLS headgasket, and rebuilt head - this motor is bulletproof.
-SHOWROOM Condition
-Very minor rock chips (mostly front bumper and a few on the mirrors and fenders)
-ASC Light wills always be on dash (ASC disabled thanks to Nick Glantzis’ software update)
-OEM BMW Battery just put in (less than 3k miles)
-Solid Compression Test Numbers
Measured Fall 2009; roughly 58 degrees outside
Cylinder 1: 154
Cylinder 2: 150
Cylinder 3: 152
Cylinder 4: 152
Cylinder 5: 152
Cylinder 6: 154
-Last Dyno Numbers using Dynojet @ APG Performance:
435 rwhp / 377 @ 15.1 psi
-VIN# WBSBG9320TEY72748
I originally purchased the car in June 2003. During this time I had ran a carfax and even took it to Patrick BMW Dealership in Schaumburg, IL, for an inspection. The carfax turned out clean and the inspection came out in all good news.
A couple of years ago, I posted this car up as a feeler and somebody had ran the VIN via Carfax. An accident had been reported on my vehicle in Iowa from year 2001. This did not appear linked to the VIN # until 2008 --- 7 years later. It did not come up in the Carfax report when I originally checked in June 2003.
Since then, I've been in contact with Carfax to see if there was a mixup in VIN #s and why this was not on the original carfax report that I ran. Apparently, police reports may take up to years to be reported and linked to a VIN. My M3 sustained some kind of damage to the driver side.
On the plus side, I had this car professionally inspected and have had no issues driving it for the 7 years that I've owned it. Any potential buyers, I will gladly let you fully inspect or take to a local dealer to do an inspection.
I hide nothing and still label this M3 as MINT/CLEAN!
I've owned this car for 7 years and only put 20k miles on it since. This car has been babied. Seriously, I've been made fun of for lack of driving it. I'm just too paranoid to take it anywhere and want to keep it in prestine condition. I don't see what's wrong with that. Ha!
I am looking for $19,250 with the Fikse Mach V wheels /Advan Neova tires, as currently on the car --- or, $17,250 with the replica LTW Wheels/Yoko ES100 tires.
Serious buyers or any questions, please PM.
-Mark
New photos from this weekend:
Photos edited to show amber corners and "clear" corners:
Here is a pic of most of the receipts during my ownership and some even prior.
I have history on PDF. Buyer will receive history.
-2 Door Coupe
-Non-smoker
Factory Options
-6 Disc CD Changer
-OEM Car Alarm
Exterior
-Front plate delete
Interior
Engine
-s52 3.2L OBDII
-ARP Head Studs
Turbo & Components
-Tial ByPass Valve
Transmission
-New Bosch Starter
Suspension
-Motorsport X-brace
-New OEM Tie Rods
Brakes
-Brembo Rotors
-Hawk HPS Pads
Wheels/Tires
OR
Spare:
Additional Notes
-SHOWROOM Condition
Cylinder 1: 154
Cylinder 2: 150
Cylinder 3: 152
Cylinder 4: 152
Cylinder 5: 152
Cylinder 6: 154
-Mark
I just wanted to beat srtmike to the punch for the first post on this sick *** ride and say this is the cleanest e36 build I've EVER seen. I totally want this, I'm totally baffled by how clean this ish is and I really hope he gets what he's asking. TTT!!!
Only vids I have are on dyno. What site can I use to host besides youtube?
Thanks fellas!
Official Spring Bump! Open to offers and willing to work with potential buyers.
The car has been sitting in storage throughout the winter and will be insured to drive beginning in April.
Nice ride......god knows how you work on it though. I struggle with my civic and there is loads of space down by the turbo! It took me at least 3 looks to see where it fitted on that car....I was wondering how all the exhaust gas got out the tiny hole (which I now see must be the wastegate hole!)
Update: A potential buyer came out to see my car, had a Chicago BMW-specialized shop do a Pre-Purchase Inspection on my car. Results came out GREAT. Very solid Compression Test numbers and Leak-Down Test numbers were very strong.
I have a copy of the results and any other potential buyers can call the shop for a reference.
I've had over 2 dozen people inquire about the car. A lot of lowballs and a lot just not in the price range I have in mind. I'm still looking for the right amount. I am not in a rush to sell, but definitely want it sold.
I WILL negotiate and make a deal to get it sold. This car is MINT. Strong motor. Fast car. Beautiful original interior. Suspension, Brakes, every last bolt has been replaced.
Asking: $19k with Fikse Mach V wheels / fresh Yoko Advan Neova tires
or $17k with LTW reps / Yoko ES100 tires
BUMP!
BUMP!
mpty3
Apr 21, 2011 11:28 AM
