need help new h22a4 build
Old Sep 29, 2010 | 08:45 AM
walker456's Avatar
Default need help new h22a4 build
i got a h22a4 for a 100 bucks and i need some idea on what to do to it info:
it's going in to an eg coupe
all motor
spending 250o-3000 on motor
and i got 94 integra rear brakes for the convesion do i need integra rear brake lines
building over time
its going to be a daily diver
so i will like to make it last
trying to make 260 to the wheels
i forgot will be doing h2b
will give rep points
thanks
Old Sep 29, 2010 | 12:33 PM
walker456's Avatar
Default Re: need help new h22a4 build
bump
Old Sep 29, 2010 | 12:37 PM
SL0WEGG's Avatar
I use integra cables for my rear disc conversion.
So you're looking to spend 2500-3000 total? Do you already have the h2b kit and transmission and all that other stuff? Because if you don't you will spend atleast half of that going h2b. With the other half You won't be able to do much to reach your 260whp goal.
Old Sep 29, 2010 | 12:56 PM
walker456's Avatar
my bad 2500-3000 just for the motor
Old Sep 29, 2010 | 01:25 PM
SL0WEGG's Avatar
You could potentially roll mahle gold 11.5:1 pistons, send the head off for a port job and throw in skunk 2 pro series valve springs/retainers and pro 2 cams. will probably go a little over your budget. But this will probably be the best bet with that amount of money.
Old Sep 29, 2010 | 01:51 PM
walker456's Avatar
thanks
Old Sep 29, 2010 | 02:09 PM
walker456's Avatar
anyone else
Old Sep 29, 2010 | 02:17 PM
DSRxCandyh2bEG's Avatar
What crank/rod combo r u planning on going with? Decided on cams yet?
If this is a daily driver, some skunk 2 pro 2 cams will get you close to the hp goal. Next Is Intake manifold and header... I miiiiiight have a header for sale but it would probably annihilate your budet so you would have to lookout for a cheaper swap header...
Old Sep 29, 2010 | 02:34 PM
walker456's Avatar
crank/rod combo don't know any recommendation
Old Sep 29, 2010 | 03:10 PM
jdmH2Bek4's Avatar
h23 crank and some eagle rods!!!
Old Sep 29, 2010 | 10:14 PM
Depends, what year is your block. I get mixed info on the subject but I believe your block is a 55mm main bearing block so an h23 crank wouldnt work. Look into a 97mm f23 crank and some aftermarket rods would do the trick. i prefer Carillo but there are many others out there, such as eagle like stated earlier.
2500-3k is kinda on the low side for any build but maybe you can pull it off...
Old Sep 30, 2010 | 08:34 AM
walker456's Avatar
i'm buliding over a long period of time so i can bump the limit to around 4k
Old Sep 30, 2010 | 09:38 AM
A long term build will make your budget more doable. Its when you are in a rush things will get expensive.
Just a suggestion, use OEM bearings just because you can have exact clearances. Its a preference of mine, but not 100% necessary.
Old Sep 30, 2010 | 10:19 AM
lunatics209's Avatar
I know Danny built a budget monster h2b a while ago. It made around 260 whp and ran a best of 11.4 I think. Here's the link but pics can't be seen.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/six-sigma-racing-quartersports-2-3l-h2b-crx-budget-build-monster-1937260/
Old Sep 30, 2010 | 10:39 AM
https://honda-tech.com/forums/showthread.php?t=1937260
I think that was Derick from PED and Danny Tran when Six Sigma used to be in Stockton. It is doable but look at the list of freebies. haha. Also, that was a super budget build, not so reliable for a daily driver. It's an option though.
Old Sep 30, 2010 | 04:02 PM
walker456's Avatar
yo half of that stuff was a freebiee
Old Sep 30, 2010 | 09:13 PM
JDM_CD7's Avatar
You can throw some Type-S pistons in there.... i'm selling them
Old Oct 1, 2010 | 06:14 AM
walker456's Avatar
my bad whats the cr on them was it 11:1 also how much u selling for
Old Oct 1, 2010 | 06:16 AM
walker456's Avatar
how much for the headers
Old Oct 1, 2010 | 07:41 AM
Golden Eagle's Avatar
To retract from my previous post........
I would stay with OEM crank and Eagle H beam rods with the ARP Rod bolts, which is a very dependable combo. As for pistons, you can go with the type S or if using aftermarket, you can't go wrong with Mahle.
Old Oct 1, 2010 | 09:20 AM
pm'd
Old Oct 1, 2010 | 09:33 AM
Yes they were freebies. Didn't you say you had a 4000 budget? Pretty sure 4 grand will cover all those stuff they had gotten for free.....
Old Oct 1, 2010 | 07:49 PM
walker456's Avatar
yo i just wanted to know if i get the oem crankshaft knife edged will that do anything for hp gain
Old Oct 2, 2010 | 06:29 AM
walker456's Avatar
bump
Old Oct 2, 2010 | 11:33 AM
JDM_CD7's Avatar
Selling them for $200 shipped.
Yes they are 11:1
PM me if you want them
