Identify This Swap?
this is the closest ocover i found could this be the one
http://cgi.ebay.com/ebaymotors/OBX-J...Q5fAccessories
right so its prolly just an LS swap like everyone is saying above, i just thought it looked different cuz of the cover.. i found it on ebay the cover its not a moroso. its called OBX Valve Cover $85 New Red
well i looked and its kinda dirty there but i wiped it off a bit and it says like b18c5 or b18c6 or something?
no one guessed it culd be a b20 u never kno with out looking at it in person or a pic of the stamp on the block. but it is a B series DOHC non-vtec
unless some one but a ls head on a b20 bc b20 have a intake manifold that is higher then the valve cover or if its a 99 to 01 b20 it has that stupid plastic chamber thing on top of the manifold
it can be either a b18a from a 90-93 Integra LS, or a b18b from a 94-97 Integra LS.
It can also be a b20. They offered 2 versions of the b20b, one high compression and one low compression, one being 8.8:1 and the other 9.6:1
The intake manifold could be swapped out, but it wouldnt make sense to do that...unless it was to clear the hood.
Best bet is a b18a or b18b1 from early model integras.
Pretty sure it is a G2 or G3 1.8L LS engine.
It is not a Moroso valve cover, it could be, as mentioned, a stock valve cover that has been "shaved" although I am pretty sure you can not shave that much off, more likely, also as mentioned, an eBay valve cover.
Look at the stamping, I can almost see it in the pic, it is at the left front end of the block directly below, [4-5 inches] the left end of valve cover, [distributor end]. 94
Your upper rad hose is kinked because its too long. Who ever installed it shouldn't even do an oil change. I'd check that thing out and see what else is improperly installed. or is it just sucked in because there is no coolant... lol. but yeah, I agree, looks like a LS of some sort. I doubt thats a C series block.
Might want to get a tie down for that battery too... looks like its taking a bit of a tumble in there. and yeah EJ1-Fernando, looks like the rad support is closer on the pass. side than driver side huh.
lol
