Bad Motor Mount but which one?
Old Sep 29, 2010 | 02:56 AM
toicy4ya's Avatar
Default Bad Motor Mount but which one?
Sup Guys,
My wife owns a 2000 Accord EX V6, for some reason the car kicks when placed in reverse from any gear when its cold. I dont have the problem when i place it back on park or drive after having it in reverse and i dont have the problem when the car is already warmed up. This only happens when its cold. I think it might be a bad motor mount but i'm not sure which one. Has anyone had this problem? Can anyone offer some feedback? Any help would be greatly appreciated.
Thanks
Old Sep 29, 2010 | 06:31 AM
jdadams12's Avatar
Default Re: Bad Motor Mount but which one?
Could be any of them, but I would check the torque strut first.
Old Sep 29, 2010 | 07:27 AM
TheMuffinMan's Avatar
He knows where you live!
Well that was helpful?
OP, the easiest way to look at them is to pop the hood, look at the mounts with a flashlight and have someone rev the motor. You should be able to see if there is any odd flex in any of the mounts.
Old Sep 29, 2010 | 09:17 AM
jdadams12's Avatar
It also might not be the mounts.
How old is the tranny fluid? Is it full? When my mounts are worn, the car will still kick going into gear when it is hot too. If you are not sure of the age/condition of the tranny fluid, then do a drain/refill - it might help.
Old Sep 29, 2010 | 08:26 PM
holmesnmanny's Avatar
What the fk is a torque strut?
Old Sep 29, 2010 | 09:10 PM
lazlong's Avatar
I think he's talkin about #1, although I would think the damper (#2) or the insulators (#5,6,10,11,13,14,15) would go bad first as they're made of rubber.
EDIT: Forgot to post link, sorry. http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Old Sep 29, 2010 | 09:14 PM
lazlong's Avatar
He's right. If it's temp related then I would check the fluid first.
Old Sep 29, 2010 | 09:15 PM
JamesDMdb1's Avatar
Do these cars use a fluid rear mount like the 94-97 auto accords?
Old Sep 30, 2010 | 02:50 AM
lazlong's Avatar
Should be rubber.
Old Sep 30, 2010 | 02:58 AM
toicy4ya's Avatar
Thanks for your feedback. I took the car to my mechanic yesterday, after having me switch gears he stated the mounts may be bad. He said the upper passenger side mount was definitely bad and should begin by replacing that one first.
I tried checking the Transmission fluid i noticed i was receiving different readings so I double checked myself on the process by confirming with the manual. The manual says to check the fluid level with the engine at normal operating temperature. Furthermore it says to shut the engine off. However ive always done it leaving the engine on. I dont recall ever shutting the car off to check the transmission fluid. Can anyone confirm this?
I recall having this exact problem with my previous car, a 99 eclipse spyder. Only it would kick going from reverse into drive and only when the car was cold due to the high idle. Once i replaced the top right motor mount the problem stopped.
Old Nov 15, 2012 | 10:23 AM
rallyraul1's Avatar
was this problem ever fixed?
Tu_Sae
Oct 11, 2007 06:15 AM
Thunder Cat
Nov 13, 2005 04:56 AM
bluskye
Sep 17, 2005 03:08 PM
Novtecdohc
Jun 24, 2005 01:16 PM
BeesDA6
Oct 6, 2003 12:20 PM
