Finally replacing Input Shaft bearing soon.
I was just wondering what kind of parts I need?
-Input Shaft Bearing
- Input Shaft Bearing Seal
Anything else?
And if you guys can.. can you provide the part number?
OEM is possible.
Thanks in advance.
It's for a 1997 Honda Civic EX 5 Speed MT
Anything else?
OEM is possible.
Thanks in advance.
check www.hondapartsunlimited.com or similar sites for the right part number.
the bearing and seal (and Hondabond) was all i needed when i did mine, but i knew the trans was otherwise in very good shape. consider a rebuild kit if yours is ragged out or shifts poorly.
you may have one already, but i had to buy a bearing puller to remove the old bearing.
i used one like this from Harbor Freight-
I can't say I recall having to use a bearing puller for removing the ISB. When I replaced mine, I also found the bearing on the opposite end of the same shaft took a dive too. Replacing it was as simple as the ISB - no bearing puller/guillotine needed.
And if the link provided above doesn't get you a factory part #, try Majestic Honda.
http://www.d-series.org/forums/trans...ng-change.html
Some snap ring pliers were helpful when I pulled the transmission apart. Also buy a few bottles of Honda MTF.
Wes V
22
Oct 25, 2003 12:51 PM
