94 civic ls swap failing CA smog. Calling all Honda Smog gurus
Old Sep 28, 2010 | 12:32 PM
95civicgsr916's Avatar
Default 94 civic ls swap failing CA smog. Calling all Honda Smog gurus
Failing 15/50
high hc co and nox
need some suggestions. Im already going to run injector cleaner and top end cleaner to get some gunk out, and possible checking the map sensor.
Any other suggestions to fix the issue
i will also take advice on how to pass without having to initially fix the issue, but i would in the long run like to fix the issue. thanks
Old Sep 28, 2010 | 12:56 PM
Former User's Avatar
Default Re: 94 civic ls swap failing CA smog. Calling all Honda Smog gurus
^I reduced the size of your image.
When HC and NOx are both high, one must consider the possibility of a bad cat.
Old Sep 28, 2010 | 01:10 PM
Mrhiguy's Avatar
First check and make sure your O2 sensor is working properly. If it's not. Then the Air fuel ratio will not be correct for the Catalytic converter to operate properly.
Old Sep 28, 2010 | 02:25 PM
Thanks for reducing the image. I have a spare o2 I'll try in there and I hope to jebus I don't have to buy a cat. I'll keep trying stuff.
Bump
Old Sep 30, 2010 | 03:17 PM
xlilriceboix's Avatar
how come the report show up as a intergra if your car is a civic
Old Sep 30, 2010 | 05:23 PM
TunerN00b's Avatar
I would assume it is because a Civic with an Integra engine is smogged (and must conform to the requirements of) an Integra.
This is assuming the OP had the car put through the BAR and the swap is certified.
Old Sep 30, 2010 | 05:50 PM
phaphon's Avatar
i failed too they told me its my cat so i have not went back cause those cost to much
Old Oct 13, 2010 | 10:38 PM
bump. i was hoping their were more gurus out there
Old Oct 13, 2010 | 10:41 PM
harms_is_back's Avatar
yea they would just recomend a shady smog spot to bad your all the way up north could have helped you out ;P
Old Oct 13, 2010 | 10:54 PM
Samuraij's Avatar
Superfly
out of curiousity how much does a new cat cost?
Soup Slayer
Oct 18, 2013 01:53 PM
91whitecivic
Feb 26, 2011 11:51 AM
cantbetouched24
35
Oct 6, 2010 09:01 PM
n_t_civic98
Aug 19, 2007 07:23 PM
boots420
37
May 18, 2007 03:35 PM
