Is del sol shift linkage for a b series different than the eg and integra?
nada. i mean 92-95 del sols are EGs but the shift linkage was made differently, so it couldn't be swapped over from a coupe. you'd need a sol's B series shift linkage if you need a replacement.
The Del Sol is the oddball, its exclusive to itself, its longer than a normal B-series linkage.
ok thanks guys i thought so but just wanted to double check before i bought the sol linkage. The rear t brackets are the same tho aren't they?
Could anyone measure and post it in this thread in case anyone needs to ID a linkage later? I hear they can look the same when not next to each other.
Either way, text descriptions, especially length, would help people for a long time as log as they search.
Eg2707
Feb 15, 2008 12:12 PM
SOLvtec
Oct 27, 2006 09:30 AM
Jayboy
Mar 29, 2005 02:00 AM
