Way to get better rod/stroke (r/s) ratio?
Yeah, by changing the length of your rods, the length of your stroke, or both. Basically, to get your rod/stroke ratio closer to 1.75, you'll need longer rods, a shorter stroke, or a combination of the two. In any case, you will require custom pistons.
You only really need a 1.75:1 rod/stroke ratio if you are planning to rev the dog **** out of the motor. For reference, bike engines run close to that rod/stroke ratio.
Quick searching on Google found this: B17A1 motor from '92-'93 Integra GS-R has a stroke of 81.4mm. Running that crank with your B20B4's rod's would net you a 1.68:1 rod stroke. Of course, with the B20A4's pistons, this would drastically lower your compression ratio, so custom pistons would most likely be needed, depending on your goal(s). This, of course, assumes that the B17A1's crank would fit in your B20B4's block...
There are tons of people who have proven that the rod ratio on the ls/b20 crank can handle rpms. It's been talked to death on this forum. It more important to think about the other key points in building reliable motors. Things like the pistons, rod bolts, the machine work, time put into planning and building the motor. There is an excellent build thread on the allmotor forum
Black R
337
Jun 28, 2006 08:49 AM
LSVTEC_ALLMOTOR
14
Dec 20, 2004 04:59 AM
DAYUIZ
Dec 26, 2001 06:33 PM
