need help wire crx
Old Sep 28, 2010 | 05:10 AM
bee015's Avatar
Default need help wire crx
i has a 1990 crx dx model and im trying to drop a b16 in but the wireing i has a si wiring harness and on the drivein said there one wire that dosen't match up i wanted to know that had to cut it and add another pug
Old Sep 28, 2010 | 05:17 AM
Bludger's Avatar
Default Re: need help wire crx
I has no stand under you
Old Sep 28, 2010 | 06:06 AM
JacksonD's Avatar
^x2. you need a b series harness, try getting one out of a del slow
Old Sep 28, 2010 | 06:31 AM
tx_ej8_49's Avatar
No.
What you need to do is use the STOCK harness for that chassis. If it is Dual point(2 injector) it need to be converted. If it is multi point(4 injectors) you are in good shape.
Depending on what manifold you are using, some plugs will need to be extended. Depending on what ECU you are going to run obd0 or obd1 you maybe need to run the wire for the knock sensor. And since no USDM crx/civic came with VTEC, you will need to run the 2 wires from the ecu plugs, to the motor and ground the pressure switch to the motor....or wherever you can find a GOOD ground.
PM me if you have any other questions or you need a harness made.
-Ryan
Canadian_EF
Aug 6, 2009 08:56 PM
efhatchbackracer
Oct 21, 2005 12:18 AM
HCRX311
Dec 9, 2004 09:37 AM
cRxAuDio
Oct 5, 2003 03:54 PM
