Hmmm, I need some help.
A long story short I purchased a head i would like to rebuild. The head is from a 1989 honda Civic DX stamped PM3-1. I want it on a 1989 honda CRX Si it is a D16a6 block. The head is cracked on this block and I need a quick solution. Hopefully this is it.
It isnt the optimal way. But time and expense it requires it if possible.
What else do i need?
Timing belt from 89 civic?
Will i have to change my cam?
Can I use the head gasket set from my d16a6 head on this head?
I know it is noob questions but I have so many conflicting answers I only want the right answers.
Thanks guys
Thanks guys
https://honda-tech.com/forums/showth...6a6+head+d15b2
Try searching 'd16a6', 'd15b2' and 'head'. You get quite a few results that answer the most of your questions.
you might as well rebuild it while your at it theres a kit on ebay for like 184 and it has every thing you need, timing belt, gaskets, bearings, rings , oil pump, ect. You do not want to use your a6 head gasket, get a head gasket corresponding to your head.
B_Swapped93
Dec 17, 2012 03:07 PM
killer6993
Feb 18, 2005 12:11 PM
