high idle 2000rpm
Old Sep 27, 2010 | 05:54 PM
89civicsiowner's Avatar
Default high idle 2000rpm
my d15b swap idles at 2000-2500 cant get it to drop below that and if im driving and it drops below 2500 in gear it falls on its face, any help?
Old Sep 27, 2010 | 06:08 PM
Oedwards's Avatar
Default Re: high idle 2000rpm
I would start by checking the spark timing, and checking for vacuum leaks.
Old Sep 27, 2010 | 06:10 PM
i have played with my timing, ill check my vacuum lines
Old Sep 27, 2010 | 06:19 PM
Oedwards's Avatar
It would be better to set it to spec. I believe this to be somewhere around 14 or 16* btdc with the service connector jumped.
Old Sep 27, 2010 | 06:20 PM
~sp33~'s Avatar
EFB055
More information?
Has it always done this? Did it start doing it after you 'fixed' something?
When you say you 'played' with your timing, did you try setting it to factory specs?
What's the power like above 2500? Does it rev clean?
Old Sep 27, 2010 | 06:28 PM
this is after a d15b vtec swap runs great above 2500 dont have a working timing light when i need it, there are some vacuum lines unhooked but im pretty sure they go to the ols map sensor what do i do with them?
Old Sep 27, 2010 | 09:24 PM
~sp33~'s Avatar
EFB055
Was it a firewall mounted map sensor? And you're now using one that's connected to the throttle body?
If you haven't looped that line then the engine is drawing air through there. Trace the line back to the intake manifold and block it off.
Having the line not blocked will cause the engine to race at idle (idle high)
Dc4iNtEgRa
10
Jan 10, 2008 05:45 PM
Tatakai
Apr 25, 2007 10:41 PM
275Performance
Jan 25, 2007 09:13 AM
Stoich
28
Jul 5, 2005 09:29 PM
