dc2 front tower bar on 96-00 civic install help
Old Sep 27, 2010 | 05:48 PM
cilvia's Avatar
Default dc2 front tower bar on 96-00 civic install help
so i bought a dc2 front tower bar for my 97 civic ex, and i read that they will fit...BUT the spot welds on the tower where it looks like it should be drilled out, doesnt line up with the tower bar mounting holes!! the two spot welds on each tower looks closer together and closer to the engine than where my bar is supposed be mounted!!...
did i get a wrong tower bar?? or is everyone having the same issue where you got to align yourself and drill out??
another thing i heard is theirs two layers of sheet metal that the strut tower is made up with, and the bottom layer has drilled out holes where the 99-00 si civics had their tower bars mounted...can anyone confirm this and if it is the actual holes that need to be drilled out?? or if it leads to the same spot welds on the top allready?? thanks
Old Sep 27, 2010 | 05:54 PM
b20hatchek's Avatar
Default Re: dc2 front tower bar on 96-00 civic install help
why didnt you just get the tower bar for a si?
Old Sep 27, 2010 | 06:04 PM
fv8s's Avatar
a picture will help
Old Sep 27, 2010 | 06:13 PM
cilvia's Avatar
got this for cheap, the color design, and thought the si, dc2 front strut tower bars were the same bolt so why not
Old Sep 27, 2010 | 06:40 PM
cilvia's Avatar
here are pics of the mounting holes being apart from the spot welds and the length of the holes apart which is 1-3/4"...does this seem right??
Old Sep 27, 2010 | 08:14 PM
cilvia's Avatar
anyone?? or can anyone tell me if the bolts are as pictured supposed to be 1-3/4" apart?? if so ill align and mount from there
milanoteggy
Dec 11, 2012 07:08 PM
oldskool teggy
Suspension & Brakes
Dec 15, 2008 07:36 AM
oldskool teggy
Suspension & Brakes
Dec 11, 2008 08:41 PM
grandam
Suspension & Brakes
Sep 18, 2007 06:46 PM
