H22A into 6th Gen Accord Wiring help!
Old Sep 27, 2010 | 03:04 PM
ricb20vtec22's Avatar
Default H22A into 6th Gen Accord Wiring help!
I am swaping a H22A into my 2001 accord i need help wiring up my distributor and IACV. I have searched tirelessly for this information and have found nothing. Can anyone help me?
Old Sep 27, 2010 | 03:12 PM
Default Re: H22A into 6th Gen Accord Wiring help!
Any information would be great thanks in advanced
Old Sep 28, 2010 | 04:24 PM
Anyone????
Old Oct 10, 2012 | 09:58 PM
xlankan's Avatar
bump need the same help please and thank you
Old Oct 11, 2012 | 11:10 PM
holmesnmanny's Avatar
You need an h22a obd2 oil pump assembly. If your h22a already has a crank sensor on it then it could be plug and play if your sensor connector fits on it, which it could.
http://www.hondapartscheap.com/parts...p-oil-strainer
part 3
for the iacv, I'm not sure cause I believe you have a 3 wire plug and the h22a uses a 2 wire.
You're gonna just need to find out what the three wires for the accord iacv connector do. I assume you're gonna be buying a manual of some sort for both cars ( i use alldata and mitchell on demand), then you can go to "wiring diagrams" and make sure that the pins for each car are the same as well. You're gonna either need the '96 obd2 h22a ecu that doesn't have immobilizer or you'll have to figure out how to get the immobilizer to work if you choose to use a 97+ h22a obd2 ecu.
Old Oct 15, 2012 | 06:53 AM
xlankan's Avatar
i need help with the distributor wiring and is there a jumper harness or conversion harness i can use to covert it from OBD2 to OBD1?. thanks
D97x
Apr 23, 2018 11:03 PM
jinxster
Jun 12, 2003 01:49 PM
