front wheel drive, new tires in front??
Old Sep 27, 2010 | 02:57 PM
zx2gotboost's Avatar
Default front wheel drive, new tires in front??
With a front wheel drive cars, like out hondas.... if 4 tires neded to be replaced, and you bought 2 brand new tires.... Where would you put them
A) Front
B) back
Old Sep 27, 2010 | 03:14 PM
alphalanos's Avatar
Default Re: front wheel drive, new tires in front??
For safety they go in back. This reduces the chance that the car will oversteer or spin out.
For people that dont care about that they can go in front to increase life of the whole set or get more grip up front assuming its a better (stickier) tire.
Old Sep 27, 2010 | 03:39 PM
TunerN00b's Avatar
A) Front
B) back
Since 4 tires need to be replaced, it doesn't matter where you put the first 2, as the other 2 new tires will go on the other axle.
Old Sep 27, 2010 | 04:18 PM
nsxtasy's Avatar
H-T Order of Merit
If you have four tires - hopefully all of the same make and model - most tire dealers (including the Tire Rack) will tell you to put the ones with more tread depth (such as new tires) on the REAR. The reason is exactly as alphalanos describes; they will provide better grip in the rear. As a result, the car will have more of a tendency to understeer, i.e. to plow straight ahead when turning, which is considered safer than oversteer, in which the rear end has a tendency to spin around on you.
However, most FWD cars wear the front tires faster than the rear tires. So, if you want all four tires to wear out at about the same time, you will need to put the tires with more tread on the FRONT. If you decide to do this, just be aware of the possibility that this will increase oversteer in the car's handling.
Old Sep 28, 2010 | 09:16 AM
ok, so they did good by putting them in the rear..however, see my other post. I "paid" for a 4 wheel aligment, and my steeing wheel is still crooked!
Vtec04
Jan 22, 2017 05:55 AM
vtek9
Aug 11, 2010 06:27 AM
Evolution-93-Ex
Feb 17, 2008 09:34 AM
LsHoney84
May 25, 2007 11:38 AM
TOO MUCH TORQUE
Feb 8, 2007 11:57 PM
