B Series Bottom End
I've got a b18b bored to 81.5mm with SRP 9:1 pistons, eagle crank with eagle rods..block also has ARP head studs installed willing to part it out if needed as well...email me if your interested i can respond faster that way cbartlein1@yahoo.com...also have a JDM b16A head if you would be interested in that as well.
Got a built bottom end with low compression pistons, eagle rods, darton sleeves, all new own parts, moroso racing oil pan, ati harmonic balancer, arp head studs... Check thread asking 1800 obo very negotiable tho
I have 5 different ones:
95mm stroker 86mm bore 14 compression 1500used
92mm stroker 86mm bore 13.5 compression 1800new
87.2mm itr crank 86mm bore 13compression 1300new
89mm stroke LS 81mm ctr piston 800used.
Pm me or email me gbrtuning@aol.com if interested.
I have a stock gsr longblock it had 102 k on it when pulled and ran fine.I was going to pull it apart and fully build it ths winter but I have since decided to go k series .
