swap question
droppin in a GSR b18c1, got the mounts, but the driver side mount is the 2 hole, and the motor has the 3 hole post
, wut mount post can i use so it can fit the mount? i heard the b16 mount post was the rit one to use?
also wut rear mount T/L bracket is it, heard it was a 90-93 DA intrega one but just want to be sure
any help would be appreciated
thanks
, wut mount post can i use so it can fit the mount? i heard the b16 mount post was the rit one to use?also wut rear mount T/L bracket is it, heard it was a 90-93 DA intrega one but just want to be sure
thanks
thanks
thanks
sounds like your trying to use the d series post bracket on this gsr, not gonna work. you need the bracket from a 90-93 integra. also what trans are you using? you dooo need the teg t bracket but the bolt holes are diff sizes whether its from a hydro trans or cable trans. isnt a big deal tho you can drill em out if you need to.
i know its not d series, the mount post i need has 2 stems but not sure wut motor it is from tho?
using a b16 cable tranny
ok so the t bracket is rit, ok just drill the holes bigger, sounds easy haha
4gencivicef9
Apr 16, 2007 04:37 PM
Down Shift Motoring
10
Mar 6, 2006 07:33 AM
PhoBichNga
Jul 21, 2002 11:21 AM
