Boost not holding steady in 3rd and 4th gears..
Trying to figure out causes that would make the boost "Wavy" in 3rd and 4th gears.. Car seems to hold fine in 1-2.. spins in 1st pretty bad, second seems to hold well at 10psi. When I hit third it starts waving some... might go to 11psi or so.. 4th its pretty bad, I can feel it spiking to 13psi and then back down, up and down.. Im running a TIAL 38mm wastegate controlled by a Greddy profec B spec II. Gain is set to the lowest setting of "5".. Im kind of stumped here. Any ideas to lead me in the right direction?
aleks77
Nov 24, 2008 04:57 AM
