Do these Cams Look like Type-S or Reg. H22 Cams
Old Sep 27, 2010 | 06:19 AM
ken2830's Avatar
Default Do these Cams Look like Type-S or Reg. H22 Cams
Hopefully some1 can kinda help me..Not the best pix but hopefully some1 can spot if there type-s or regular h22 cams.. thanks
BTW its an F20B motor
Old Sep 27, 2010 | 07:25 AM
ken2830's Avatar
Default Re: Do these Cams Look like Type-S or Reg. H22 Cams
Originally Posted by PirateMcFred
That's not enough information to tell you anything but guesses. I'd guess it's the crappy auto cams. Pull them out and measure the lobe height with a set of $10 calipers.
Yea i know, I just figured its a long shot to see if any1 can figure it out thru the pix,cus they look kinda grayish/bluish to me...Ill try to see if I can find a caliper of sum sort to measure atleast 1 lobe while the cams r still in the engine,i know not the best way, but i think i can manage to measure 1 lobe
Old Sep 27, 2010 | 09:30 AM
ken2830's Avatar
You should be able to measure the intake VTEC lobe if you pop the cam cap bridge on Cyl #1 at TDC. It should not require major surgery.
Will do..thanks..
bottleFed22
Jan 10, 2012 11:36 AM
ken2830
Sep 28, 2010 06:12 AM
Ntercooled
Dec 20, 2005 11:56 AM
Quiks66
Apr 13, 2004 09:10 AM
DS1
Sep 3, 2002 10:03 AM
