88 dx to 90 dx dash harness
Old Sep 27, 2010 | 06:11 AM
boosted26's Avatar
Default 88 dx to 90 dx dash harness
My question is on the cabin harness from headlight to interior will an 88 dx work on a 90 dx? I did alot of searching and found one thread that says the 88 is different having a different plug used to connect the rear harness to fuel pump rear tails and wiper. I read one had 15 the other had 21 pins. I don't have my original 90 harness to check but I have an option to buy an 88 harness and does anyone know any other differences
Old Sep 28, 2010 | 08:54 AM
boosted26's Avatar
Default Re: 88 dx to 90 dx dash harness
Bump! Any knowledge is much appreciated
Old Sep 28, 2010 | 09:03 AM
tx_ej8_49's Avatar
I have only ran into this problem one time and it was a hack together car. 90 dp-mp engine harness, 90 dash harness, 88 ignition harness, 88 dx hatch. A LOT of the plugs are different BUT the car runs and very few things work. It was a drag car project a customer of mine was doing and he just wanted it to run. This is what he had to work with.
You best bet is to find a 90 dash harness to cut out all the bullsh1t.....hope this helps.
Old Sep 28, 2010 | 10:04 AM
boosted26's Avatar
Thanks for the input my problem is back when people first started doing the dpfi to mpfi swap my buddy did one in a civic n helped me on my rex. Well long story short he had me put a whole new harness in the car with the si engine harness n hack **** to make it run and now I'm sick of not having anything but my speedo work. Its been so long now tho idont remember wat all I did or changed so I'm trying to figure out what I have so I know what harness I need I think basically I just want to find the stock dx and modify it like I should have in the beggining but I'm trying to figure out if the si has the same plugs under dash and all minus the engine harness connections in which I already have the si engine harness
Old Sep 29, 2010 | 09:02 AM
boosted26's Avatar
Ok so did more searching and found the 88-89 will not work in my 90 dx. I have the si engine harness and si fuse box so can I use a 90-91 si cabin harness plug n play? I know if I get a dx cabin and engine I can revert back to dx fuse box n rewire the engine with my si for mpfi but id much rather plug in an si and everything work but can I?
Old Sep 29, 2010 | 12:42 PM
tx_ej8_49's Avatar
It sounds like it would work. I know that with a correct/matching si dash harness/si engine harness, si fuse block, and the correct year ignition harness it should work. If are in texas i can get you all fixed up...usually that is not the case tho.
Old Sep 29, 2010 | 07:30 PM
m2theizzy's Avatar
i guess it will work i put an 88 dash in my 90
Old Sep 30, 2010 | 06:31 AM
boosted26's Avatar
Thanks tx I'm almost positive it will work minus swapping a few dash cluster items I just was trying to find out for sure so I didn't waste time and money. And yea I live in pennsylvania a few to many hops skips and one giant jump away. And m2theizzy swapping a dash from an 88-89 to 90-91 ain't nothin but thang! Wiring is a whole new ball game though.
syobwoc sallad
Mar 19, 2014 03:50 PM
Rease3
Dec 27, 2010 12:24 AM
m2theizzy
Nov 23, 2010 08:07 PM
jdmef9gsr
Oct 14, 2004 12:09 PM
