D16Y7 -- Turbo....or high compression?
D16Y7 with current plans, of a high compression mini me build. Thanks to craigslist, ive already got the Y8 head, manifold, along with some NPR 75mm high compression pistons. I know I can continue buying parts on the cheap, and eventually piece it together. My question is....is it really worth tearing the motor down...installing pistons (with integra LS rods), and obviously the rest for the mini me build. Or should I just scratch that, and turbo charge my y7. I'm not gonna lie, I love a BOV sound!!!! I really don't beat up my car. I got arrested once for reckless driving, so I can honestly say I don't street race, and I always look 3 times before even going half throttle!!!! What do you all think? Any and all info is great. Thanks
They call me the part of a womans vagina that causes pleasure.
i would go to the forced induction section of HT. Hardly any one in GDD pushes a honda these days ( even tho i still have my integra).
Honestly if I were you i would sell the SOHC junk, buy a B series...bump compression, build head, decent size turbo, good tune, make 400 whp and still get 35 MPG on pump gas.
Apparently I accidentally posted this in the wrong forum. For those with advice....thanks.
Anyways, now that I am in the correct forum....what do you all think? I wouldn't mind a B-series....im just not into installing new mounts, tranny, brackets, etc. It just seems like a mission. It may be easy... but I wouldn't know as Ive never done one. Any and all info is greatly appreciated. THANKS TO THOSE WITH ADVISE!!!!
I would reccomend a turbo for you because a n/a d series is costly, much more than a decent turbo setup and the power isnt even worth it.
n/a built d-series is expensive and not worth it
d-series turbo is a great setup with plenty of power for daily driving
n/a built b-series is expensive but is worth it
b-series VTEC turbo is expensive, a great setup and with PLENTY of power for daily driving
b-series non-vtec turbo is fairly priced and plenty of power for daily driving
h-series is tedious but its not too expensive and plenty of power for daily driving
as far as posting in the wrong forum, there's a reason why there's some sort of organization so things are easier to find. I know you're looking for answers but you looked for it in the wrong place
good luck
good luck
good luck
good luck
now a d on boost is a different story. just look at the 700whp d series wagon in supertstreet. you could easily get 300 on a turbo d with a good setup and tune and run it forever as a rather quick daily.
point is, the reason why people dont do NA d builds is just because its worthless. if you want to do it just to be different, more power to you, but prepare to be in many cars rear view mirrors.
OP, you made a painful wrong turn into GDD. You'll be more welcome here.
I cleaned up your thread. Just PM me if you'd also like the thread copied into the Force Induction subforum.
Sounds like turbo is the clear winner here! I guess thats a good thing, b/c once I again I love the BOV sound (It actually turns my wife on when she hears one sound off!!!!) Anyways, anyone know how much power can i hold safely level with a stock y7. The block is in excellent condition. The motor does not tick, runs smooth, with A/C and PS. I really dont beat on it, but im sure with a turbo.....i'll be on it a little more than usual.
Also...would it be worth it to do a mini me build...than turbo? Or would it be safer to get a good turbo kit and boost say 10psi? Does vtec react better to a turbo, or does a non-vtec react better to a tubo?
Whats needed to swap a b series motor. I know mounts, engine, etc. I mean...do mounts have to be welded on, or would it bolt on to the stock d series? Does tranny line up the same, or does that have to be worked with also? Axles.....? linkage?
a bseries is a straight drop in. it'll bolt up, mount up, and wire up all the same. pretty easy drop in motor. takes about 2-3 hours after getting the other one out.
linkage you need special sometimes car dependent.
but to the original question. if you have the time and money i say throw on that mini me then turbo it. if moneys tight just turbo it. you can easily net 300+ hp with a daily D.
An NA D series is a complete waste of time. If you want more power, turbo it. The stock engine is safe into that 220-240whp range and with a cheap Eagle/Vitara build, you're looking at a safe 400whp. Its your only option if you want to make any power
The actual VTEC system itself really doesn't have much of an effect on power on a turbo car IMO.
Not on the stock bottom end.
