Want to Buy Want to Trade/Want to Buy
Need a new alternator pigtail for a 95 civic (green pigtail)
Old Sep 27, 2010 | 01:00 AM
SD Ricer's Avatar
Default Need a new alternator pigtail for a 95 civic (green pigtail)
I'm looking for a new pigtail for a 95 Civic. Please let me know if you have one or know where I can get one.
Old Sep 27, 2010 | 06:30 AM
SD Ricer's Avatar
Default Re: Need a new alternator pigtail for a 95 civic (green pigtail)
Bump.
Old Sep 27, 2010 | 03:45 PM
SD Ricer's Avatar
Anyone?
Old Sep 27, 2010 | 03:51 PM
ej8b16a2's Avatar
HONDA DEALER OR LOOK FOR THE NEAREST ALTERNATOR REBUILDING PLACE,THEY SHOULD HAVE ONE IN STOCK
Old Sep 27, 2010 | 04:16 PM
SD Ricer's Avatar
Dealer sells in with the whole wire harness.
Old Sep 27, 2010 | 04:19 PM
ej8b16a2's Avatar
THEN JUST GET IT FROM A LOCAL ALTERNATOR REBUILDER BUT URE GONNA HAVE TO CUT AND SPLICE
Old Sep 27, 2010 | 04:27 PM
fv8s's Avatar
if your talking about the actual plug that goes into the alternator along with the wiring i have that. pm me an offer
Old Sep 27, 2010 | 08:36 PM
SD Ricer's Avatar
PM sent.
Old Sep 27, 2010 | 08:43 PM
Joyero III's Avatar
$15 shipped. w/ a few inches of wire
Old Sep 27, 2010 | 10:21 PM
red01teg's Avatar
I have what you need too. make me an offer
Old Sep 28, 2010 | 04:48 AM
shandonwall's Avatar
Do you need the round one or square one?? I should have both, pm me.
Old Sep 28, 2010 | 06:14 AM
crx_si-r's Avatar
go to an auto parts store, like o'reilly. they sell a bunch of replacement plugs
Old Sep 28, 2010 | 04:15 PM
SD Ricer's Avatar
Does anyone have a brand new one?
Old Sep 29, 2010 | 10:03 AM
go to a junk yard................
Old Sep 29, 2010 | 11:02 AM
meloylo's Avatar
obd0 uses the same plug just so u know
Old Nov 8, 2010 | 05:58 AM
Rerock's Avatar
I bought a '99dx with a d16z6. Trying to figure out which alternator the guy used. I'm showing code 17 and 20 (p28) though everything seems to be working properly.
Curious if a '99 alt may be causing a charging issue.
How can I tell which alternator is which, and what pins go to what on each one as well.
Once I figure out what alt I have, I may need a pigtail; in which case I'll PM somebody to
buy one.
Thanks!
Old Nov 8, 2010 | 09:03 AM
Timmyflys's Avatar
if its a 99 civic you should be using a obd2 plus which is different then a 95 civic if ur using obd1 alternator with a obd1 plug the wires may not match up right
and if ur running a p28 u must have a obd2 to obd1 harnes by the ecu which will not change the alt. plug have ne questions lmk
buickboy71
Feb 15, 2011 04:44 AM
black04
Mar 22, 2005 09:15 PM
xCIVICx
Oct 27, 2004 09:08 AM
