what manifold and tb for set-up?
Old Sep 26, 2010 | 10:17 PM
Angel4768's Avatar
Default what manifold and tb for set-up?
b16a head.
port&polished.
buddyclub spec III cams.
buddyclub retainers.
buddyclub valve springs.
skunk2 camgears.
hytech header
b18c1 block.
ctr pistons.
shot peened ls rods.
85mm bored out
acl race bearings
Old Sep 27, 2010 | 08:26 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: what manifold and tb for set-up?
Are you using CTR replica cast pistons?
Based off of the displacement I would say Victor X and 68mm TB. You can go with a bigger TB if you think you need it however to fully utilize it you will need to mod the manifold to fully utilize the larger TB.
But honestly, way to go big on the block/head and skimp and pistons and rods................
Old Sep 28, 2010 | 08:02 PM
Angel4768's Avatar
Icon2 Re: what manifold and tb for set-up?
do you know if i would need bigger injectors?
Old Sep 29, 2010 | 04:17 AM
Mattb16teg's Avatar
Community Builder
Uhh yes! Yes! and YES!
440's should be sufficient for that setup.
Angel4768
May 9, 2011 12:49 PM
Angel4768
Oct 2, 2010 03:20 PM
Angel4768
Oct 2, 2010 03:32 AM
Angel4768
Sep 29, 2010 10:20 PM
Angel4768
Sep 27, 2010 12:43 AM
