Idle drops when a/c is turned on
Old Sep 19, 2002 | 07:42 AM
FLCivic's Avatar
Default Idle drops when a/c is turned on
Someone correct me if I'm wrong but shouldn't the rpm increase when you turn on the a/c?? My rpm drops and I want to know what needs to be done to correct the problem.
thanks
Old Sep 19, 2002 | 08:04 AM
Spade's Avatar
Default Re: Idle drops when a/c is turned on (FLCivic)
IACV is going out.
Old Sep 19, 2002 | 11:54 AM
Perfectionist's Avatar
Default Re: Idle drops when a/c is turned on (Spade)
IACV is going out.
Or the ECU is not getting the signal that the AC is on, so it doesn't open the IACV to compensate for the load. [B] [B]
an2ny888
Aug 4, 2004 04:33 PM
95 integra
Jun 29, 2003 08:17 AM
