What parts can I use off a 90 Si for my 88 CRX?
Old Sep 26, 2010 | 06:29 PM
Ryank327's Avatar
Default What parts can I use off a 90 Si for my 88 CRX?
I have an 88 CRX shell that I believe to be an HF. I already have it stripped out as much as the state laws will allow. Locally theres a guy with a 1990 Si for $400. Everything is good except the paint is crap and it has a fuel delivery problem.
I plan on using the whole motor and trans and all that out of it. I was wondering if there was anything else that would work off it? Rear disc brakes? Bumpers/fenders?
Old Sep 26, 2010 | 06:53 PM
OddityDX's Avatar
Default Re: What parts can I use off a 90 Si for my 88 CRX?
pretty much everything will swap. seat rails are different. If you swap the rear disc brakes don't forget the prop valve.
Old Sep 26, 2010 | 07:13 PM
Ryank327's Avatar
damn seat rails are different? Thats one thing I need. Just talked to the guy and said it doesnt have rear disc brakes, I though 90-91 Si's did? I'm going to check it out Friday so I'll have to see.
Old Sep 27, 2010 | 05:33 PM
spank88's Avatar
you must swap out the front hubs if it's a hf.
Old Sep 27, 2010 | 08:01 PM
VA THE GREAT's Avatar
do the bumpers and fenders fit too??
Old Sep 28, 2010 | 04:20 AM
michael O's Avatar
they should. I personally like the look of the 88-89 front bumper though.
Old Sep 28, 2010 | 06:08 AM
JacksonD's Avatar
there's a lot of swapping involved from an hf to si, what shell are you planning on using your hf or your si?
Old Sep 28, 2010 | 09:12 AM
tx_ej8_49's Avatar
The 88/89 fender are the same shape as the 90/91. The difference is the bumper trim on the 88/89 fender is fatter than the 90/91. They will swap over just fine.
Another difference is the corner lights, 88/89 have 2 screws that go though the light into the fender that hold it in place. The 90/91 corner lights have slots in fenders and 1 set screw in the headlight bucket.
So yes, the headlight buckets are different also between the years.
Besides the visual difference of the front bumper, the 88/89 bumper light are smaller...iirc and will only work perfect in the 88/89 bumpers..same goes for the 90/91.
SIDE NOTE:
HONDA did make that bastard year(late production) 89. I have owned about 9 of them. The late production 89's did come with door mounted seat belts.
These are just some front end differences and a little bit of honda history. Hope this clears things up for you.
Old Sep 28, 2010 | 09:02 PM
richyef9's Avatar
ok i think i have on of those late productions cuz its a 89 it came with 90 91 style tail lights and the corner lights are 2 screw styl but the shape is different i tried 89 corner lights but they didnt work or did they sell me something different cuz they kind of loook like DA corner lights but the have 2 screews please help
Xemu
Sep 19, 2006 10:23 AM
whole9
15
Apr 1, 2005 05:55 AM
evilwookie
Jan 11, 2002 04:20 PM
allmotorEG-SI
Oct 24, 2001 05:06 PM
DevineGSR
Jun 8, 2001 08:33 AM
