FS/FT 94 Civic Coupe + B swap
http://www.hondamarketplace.com/show....php?t=2573622
B series motor
B16A head
Supertech dual valve springs
OEM gsr valves and retainers
3 angle valve job
Resurfaced
00 CTR cams
Megan cam gears
GSR valve cover w/ gasket kit
Vtec solenoid
LS head gasket
B18B block freshly rehoned
New ITR pistons
LS rods
LS crank
ARP rod bolts, main bolts, head studs
Balanced bottom end
ACT Heavy duty clutch and flywheel
B series axles
HAsport mounts
Gasket kit
All it needs is a distributor, chipped ecu, spark plugs and to be built but that's about it. Let me know if your interested. I want it gone asap so make offers!!
B series motor
B16A head
3 angle valve job
Resurfaced
00 CTR cams
Megan cam gears
Vtec solenoid
LS head gasket
New ITR pistons
LS rods
LS crank
Balanced bottom end
B series axles
HAsport mounts
Gasket kit
http://www.hondamarketplace.com/show....php?t=2882519
Shell for Shell?
Shell for Shell?
