Remove OEM H22 Fuel Rail main line bolt?
Old Sep 26, 2010 | 04:08 PM
K-Spec's Avatar
Icon2 Remove threaded stud from stock H22 Fuel Rail?
Hello,
I'm trying to replace my stock h22 fuel rail with a spare one that I have. The only issue is that I cannot remove the threaded bolt that sticks out where the main fuel line connects to (see picture).
I need to remove this because my B&G fuel pressure gauge sits on top of that, which bolts into that hole.
Things I've tried:
-Inserted allen key into the hole of the bolt and turned it counter-clockwise (started bending the key)
-Sprayed lubricant oil on the bolt and tried loosening it with a table-mounted vise, which started slipping on the thread of the bolt
Any ideas?
Thanks,
Kevin
Old Sep 26, 2010 | 06:04 PM
minilogoguy18's Avatar
Default Re: Remove OEM H22 Fuel Rail main line bolt?
If you don't have a threaded stud remover set, which I'm sure you would've tried if you did, thread 2 nuts on all the way down to the rail and with an open end wrench turn the bolt that is between the top bolt and rail counter-clockwise and it should turn the threaded rod out. Never knew that could be removed from the rail, are you sure it can be removed?
civictype-r
May 26, 2010 08:30 AM
CHEFH22HATCH
Oct 10, 2007 09:22 AM
h22silvia
Mar 27, 2007 01:45 PM
4ghatch
Sep 2, 2005 08:19 PM
gc92cvc
Nov 20, 2004 06:08 PM
