IL !FS/FT MINT ROTARY 400whp '93 maZda RX-7 FD3S ! BUILT CLEAN DAILY @LOOK@
Old Sep 26, 2010 | 04:06 PM
krysted9354's Avatar
Default !FS/FT MINT ROTARY 400whp '93 maZda RX-7 FD3S ! BUILT CLEAN DAILY @LOOK@
TEXT ONLY THIS!! 608-290-8514
OR CALL 815-494-6748
11,500k is the selling price!! TRADE VALUE is 13k evo,sti,civic,350z,rx8, etc
here's a short run down...
1993 Mazda RX7 FD3S RUNS/DRIVES. . 5 speed with no grinds!!. The engine has 27,5xxk miles on it with 120PSI of compression on both rotors on a cold start.
In other words, this is a VERY HEALTHY motor. Oil is changed every 2k miles with Castrol GTX.
:excited:Do not get fooled or buy the wrong RX7.
This one has all the RELIABILITY MODS done. The downfall of the rx7's rotary engine was not because it was poorly designed but because there was too much heat due to the turbos. It is now 2010 and rotary engines have come a long way. If you do these mods, the engine becomes instantly dead reliable and able to live for a long time. That is why the Naturally aspirated 13b rotary engines have owners running their cars up to 200k miles. Because that engine produces way less heat then a turbo motor does. These mods are very expensive and ESSENTIAL for the health and longterm life of the motor. If you buy a car without these mods, chances are, the motor will tank sooner then later. Also if you buy an automatic trans RX7, chances are the motor will die prematurely from the heat the transmission produces. The mods are as follows:
:yes:engine re-built 3mm apexi seals, mild port,forged dowels,everything welded no ebay block off plates etc. ceramic coated/painted engine etc
HKS 1,200$ clutch!+ lightweight flywheel.
engine torque damper.
Intercooler (Apexi) w/ SSQV Blow off valve and hard piping.
HKS Downpipe, midpipe, HKS Hi-power catback 4"
Non-sequential OEM turbos spec-r "02
Removal of the "rat's nest" and all air-pump and emission with block of plates!
Apexi Power FC and commander tuned.
BRIDGE PORTED PLATES+2x850cc PRIMARY INJECTORS 2x1680cc SECONDARY INJECTORS ON 2ND FUEL RAIL
800cc injectors/in tank ump with swirl etc
HKS tunnel ram intake and generic filters.
all new fluids/belts/ everything working at tip tops!!
:jack:Other modifications include:
Shine Auto Re Diffuser
JDM taillights efini
Mazdaspeed CARBONFIBER Front lip
R1 Suede seats (i can include original leather tan seats also)
Stillen 17x10.5" wheels with 275 tires in the
Short shifter w/ rx8 shift **** and new boot
coilovers and all new es suspension bushings/tranny mount/engine mounts etc
ebc pads and slotted rotors!! stops on a dime!!!
NOT A SPEC OF RUST OF ANY major DENTS!!!
interior is PERFECT!! everything works as should!! power-steering works perfect and A/c is all there just needs belt/charge.
The engine and transmission is tip top! no leaks etc.
This car is extremely powerful!! 393whp on low boost 10-8-10 which is practically stock boost.
Call or text for test drive/meet.
THERE'S A LOT MORE TO IT!! but this is all on top of my head!!
Old Sep 26, 2010 | 04:25 PM
Default Re: !FS/FT MINT ROTARY 400whp '93 maZda RX-7 FD3S ! BUILT CLEAN DAILY @LOOK@
http://s256.photobucket.com/albums/h...3%20rx-7%20r1/
Old Sep 26, 2010 | 06:13 PM
Greddy95GSR's Avatar
Looks good man. GLWS
Old Sep 26, 2010 | 07:33 PM
hai_tech's Avatar
bump 4 viewing
Old Sep 26, 2010 | 08:13 PM
srt4mike's Avatar
Bump for viewing.
Old Sep 27, 2010 | 01:11 PM
RHD_EK9's Avatar
Old Sep 27, 2010 | 03:22 PM
wannabe_itr's Avatar
check my thread
Old Sep 27, 2010 | 03:23 PM
CTRinWAforsale's Avatar
PM sent ! lmk, thanks !
Old Sep 27, 2010 | 06:03 PM
mo1213's Avatar
pm sent
Old Sep 30, 2010 | 10:35 PM
Mr SPOON's Avatar
bump nice car pm sent
Old Oct 7, 2010 | 08:23 AM
C-Rex1021's Avatar
bump it up
Old Oct 7, 2010 | 08:26 AM
bostonmatty's Avatar
^^ bump
Old May 11, 2011 | 01:05 AM
j/d/m's Avatar
will pick up asap for 9.5k
Old May 11, 2011 | 03:49 AM
ovrboostn's Avatar
pm'd
Old May 11, 2011 | 05:02 AM
95integrals18's Avatar
Should prob check if the guy even still has it- thread is 7-8 months old
My_EFsedan
Northern California (Sales)
Nov 19, 2014 06:55 PM
yckan47
Jul 27, 2014 05:46 PM
krysted9354
Sep 22, 2010 01:51 PM
c0mplex
Mar 17, 2004 11:52 PM
