Mid-Atlantic (Sales) VA, DC, and MD
MD- '94 CX Hatch SHELL, K-swap Ready, Full Race, Koni/GC, ASR and MORE - PRICE CUT!!!
Old Sep 26, 2010 | 01:07 PM
Froth's Avatar
Default MD- '94 CX Hatch SHELL, K-swap Ready, Full Race, Koni/GC, ASR and MORE - PRICE CUT!!!
First off, The Shell is located in MARYLAND just outside of Baltimore.
I need to move the car out of where it's been sitting before winter/cold weather hits, so that being said...Price cut!
Asking price: $1,750 FIRM!!! , THIS WEEK ONLY.
Title is CLEAN/CLEAR!!!
CHASSIS: - Chassis has 141,XXX miles on it at the time of listing. Since the swap has sold this hasn't moved in a few months. Please keep in mind that this is cut for a K-swap, so the Pass. Side frame rail bracket is gone and the shifter hole is also gone. I do have the metal to replace those items if You wanted to go through the trouble of doing that.
- 1994 Honda Civic CX hatchback, Aztec Green Pearl. (OEM Color/OEM paint)
Brakes:
- 1993 Civic Si Rear Disk brake conversion
- 1993 Civic Si eBrake cables
- 1994 Civic CX Front brakes (Same as my 93 Si...so I didn't swap them)
- 1993 Civic Si Proportioning valve (correct for disk setup)
- 1993 Civic Si Master Cylinder (correct for disk setup)
Electrical:
- Wire tucked(mild, just side harnesses)
Suspension:
- Koni Yellow adjustable (Painted flat black)
- 500lb/in Front springrate
- 650lb/in Rear springrate
- OEM Honda new trailing arm bushings
- OEM Honda new 1996 Del-Sol VTEC rear LCA's
- OEM Honda USDM ITR 22mm Rear Swaybar (Purchased NEW)
- OEM Honda USDM ITR Swaybar Endlinks
- ASR Rear subframe brace (Black)
- 1993 Civic Si Front Swaybar 21mm
- 1993 Civic Si Front LCA's
- Full race Pro-Street Traction bars
Wheels/Tires:
- 1994 Civic CX OEM 13" Steelies with generic tires(80% tread left)
Interior:
- The ENTIRE Interior is from a 1993 Civic Si, minus the headliner.
- Rear Plastic Panels
- Door panels
- DASH (so there is no Airbag hole from being a 94, 93 dash was swapped in)
- Center Console (no shift boot, can't find it)
- Stock 1993 Civic si Cluster, 7200rpm redline and goes to 9k.
Seats:
- 1994 Del-Sol TEAL STRIPE on 1994 Civic Sliders (They match PERFECTLY)
Sounds:
- OEM Honda Integra CD player will come with the car.
- Decent speakers, Sony X'plods in the rear and Polk Audio in the front
Exterior:
- eBay amber corners.
- eBay Spoon Carbon Fiber mirrors (Real CF, just not made by Spoon)
- 6000k "white" Retro-Solutions Hi/low 55w Bixenon HID's (Amazing)
Flaws:
- The pass side rear fender has been creased slightly, damage from previous owner. Crease is around 8-10" long
- The rear bumper has some scratches from being push-started, damage from previous owner. (has been touched up)
- Left front fender and door were re-painted due to being keyed. damage from previous owner. (good job, cannot tell difference in color)
K-swap stuff left in the car:
- Pass. Side frame rail mount removed
- Shifter hole cut
- Radiator tabs relocated (for civic 1/2 radiator)
- Heater core hoses/valve (perfect setup for a K20)
- Suja 1 Clutch cable and OEM RSX-S hardline
On to the pics:
(These were taken 7/31/2010) What you see is exactly what you get.
That's it, exactly what you get is what is pictured.
If you're curious at all this would be the car in its former glory and what a simple cleaning and some elbow grease will do to put this shell back into this state.
- http://www.poopftw.com/images/nha1.jpg
- http://www.poopftw.com/images/clnh1.jpg
- http://www.poopftw.com/images/clnh2.jpg
Once again, that is what it used to look like and it could very easily be put back to that shine/cleanliness by the next owner. The paint is in great shape and just needs some washing/wax to get rid of the grime from sitting as a shell. There's a bit of surface gunk here and there but nothing that isn't reversible. This is a GREAT Platform to start from!
Once again:
Asking price: $1,750 FIRM!!! This week ONLY.
Vehicle is sold AS-IS where is.
Thanks,
-Froth
Old Sep 28, 2010 | 04:14 PM
Froth's Avatar
Default Re: MD- '94 CX Hatch SHELL, K-swap Ready, Full Race, Koni/GC, ASR and MORE - PRICE CU
Bump.
-Froth
Old Oct 6, 2010 | 02:06 PM
Froth's Avatar
Bump.
-Froth
Old Oct 9, 2010 | 07:48 AM
Froth's Avatar
SOLD.
-Froth
Froth
60
Jan 24, 2011 03:21 PM
Froth
Sep 19, 2010 11:45 AM
Froth
Jul 30, 2010 06:35 PM
Froth
29
Jul 30, 2010 02:23 PM
