Car pulls to the left after axle replacement????
Old Sep 26, 2010 | 11:27 AM
'00_GSR/R's Avatar
Default Car pulls to the left after axle replacement????
I replaced my driver side axle with a nice reman from Raxles. Everything went well and the axle fit great, but now when I accelerate my car pulls to the left. If Im driving steady or slowing down it doesn't pull, just when accelerating. Do I need to do an alignment after axle replacement? Is it possible to mess up the alignment when taking the old one out? I did have to pry some of the front suspension apart as its been awhile since its been apart.... Any help is appreciated.
Old Sep 26, 2010 | 01:37 PM
NinJa_FLiP's Avatar
Default Re: Car pulls to the left after axle replacement????
yes you def. need to get ur alignment checked esp. when messing with any suspension components..
Old Sep 26, 2010 | 03:21 PM
dc2gsr-85's Avatar
it depends on what all you took apart. you can swap axles and not touch any adjustments. if its only under acceloration then i dont think its your alignment
Old Sep 26, 2010 | 05:41 PM
'00_GSR/R's Avatar
I unbolted the fork from the lca, and unbolted the knuckle from the lca. Getting the knuckle free of the lca did require some force.... I just tied the knuckle up out of my way and that was it. Axle out, new one in and same process in reverse.....
If its not the alignment what would it be?
Thanks
Old Sep 26, 2010 | 06:06 PM
ninjaturtleEG's Avatar
uneven tires?
Old Sep 26, 2010 | 06:21 PM
'00_GSR/R's Avatar
Originally Posted by ninjaturtleEG
uneven tires?
They do all have the same Sh!tty camber wear, but it didn't pull before the axle swap.....
Old Sep 26, 2010 | 06:26 PM
'00_GSR/R's Avatar
I still have a crappy reman axle on the passenger side that I haven't replaced yet.... I haven't replaced it yet because the boot hasn't ripped yet like the driver did, but it is starting to "click" telling me that the bearing is going bad. Not sure if that would cause the pulling to the left....
Thanks
Old Sep 26, 2010 | 08:31 PM
XSIntegra's Avatar
Do you hear grinding?
Old Sep 27, 2010 | 02:08 AM
'00_GSR/R's Avatar
Nope. There are no strange noices.
Old Sep 27, 2010 | 02:38 AM
Cortez_h's Avatar
This may sound dumb but check your tire pressure in the morning. I had uneven tire pressure and caused a slight pull to the left and was more noticeable under acceleration.
Old Sep 27, 2010 | 06:19 AM
lilred86si's Avatar
over tightening of the axle nut pinching the wheel bearing will do that too... just a thought
Old Sep 27, 2010 | 07:23 AM
robodouche's Avatar
This.
Did you torque the axle nut properly?
Old Sep 27, 2010 | 08:12 AM
TwotoneC1Da9's Avatar
did you buy a reman'd oem axle or autozone/napa?...theres a very big difference, I used a napa axle once that under acceleration (3k rpms or less) made my whole car shake violently, I returned it the next day lol
Old Sep 27, 2010 | 01:31 PM
Jimmy's Avatar
Global Moderator
Get your alignment checked!
Old Sep 27, 2010 | 04:08 PM
'00_GSR/R's Avatar
This could very possibly be it. I couldn't find the torque reference so I just hit with an impact. Anybody have a torque spec for the axle?
Old Sep 27, 2010 | 04:10 PM
'00_GSR/R's Avatar
I put in the OP that I got it from Raxles. Far from autozone and napa.
Old Sep 27, 2010 | 04:31 PM
fcm's Avatar
fcm
Old Fart
You used an impact gun to tighten the drive-axle hub nut, tisk tisk tisk.
Torque should be 134ft-lb, it is on 90-98 Tegs anyway. 94
Old Sep 27, 2010 | 04:40 PM
'00_GSR/R's Avatar
Yes I know . After about 30mins on google I found the torque specs (94-01 teg) for axle replacement. I will be taking it off and re-torquing it tomorrow after work. Hopefully this is my problem.....
so others don't make the same mistake:
ft-lbs. (N.m)
Ball Joint Nut: 36-43 (49-58)
Damper Fork Bolt: 47 (64)
Damper Fork Pinch Bolt: 32 (44)
Intermediate Shaft Bearing Support Bolts: 29 (40)
Spindle Nut: 134 (181)
Wheel Lug Nut: 80 (108)
Old Sep 29, 2010 | 07:32 AM
'00_GSR/R's Avatar
Problem pretty much fixed. Axle nut was to tight. Now its just the same slightly bad alignment and torque steer that it had before. Thanks for the help.
'00_GSR/R
Suspension & Brakes
Sep 28, 2010 07:32 AM
DC2SIR-G
Feb 26, 2006 06:13 PM
BigBoulda
Jan 25, 2006 08:13 AM
Philip
14
Dec 4, 2005 08:41 AM
S13 slide
Jun 23, 2004 06:02 PM
