2004 RSX type S, ticking sound when idling?
Old Sep 26, 2010 | 09:09 AM
CoolGuy486's Avatar
Default 2004 RSX type S, ticking sound when idling?
I have a light ticking sound when the car is idling, but it goes away when i push in the clutch, and i dont hear it while i'm driving, only when idling. Any idea what this could be? thanks in advance
Old Sep 26, 2010 | 09:13 AM
CoolGuy486's Avatar
Default Re: 2004 RSX type S, ticking sound when idling?
throw out bearing maybe?? idk just throwing it out there
Old Sep 26, 2010 | 01:12 PM
Targa250R's Avatar
be professional
That noise is coming from the mainshaft bearings. Check your transmission oil level. When you remove the fill plug, some oil should trickle out of the fill hole. If it doesn't, the trans is low on oil and you should do a trans oil change. I highly recommend genuine Honda Manual Transmission Fluid. Do not use gear lube because it will damage the transmission bearings.
No. The clutch release bearing does not spin until you push the clutch pedal in, which moves the release arm and pushes the release bearing into the pressure plate fingers.
Old Sep 26, 2010 | 08:56 PM
hawaiiancb74's Avatar
perty good assessment
Old Sep 28, 2010 | 04:04 AM
dr.k20z1's Avatar
could be injectors also? my dc5S has the ticking and i know of a fair few ppl that also have the ticking. is it a tick that your hearing or like a wind noise or somthing like that?
Old Sep 28, 2010 | 08:31 AM
Evil-Mpire's Avatar
My ep3 is the same way. Take a long screw driver and put it to your fuel rail then listen on the other end more than likely you will hear really loud ticking coming from it thats the injectors. Would also suggest checking your trans fluid too just in case.
dominique91
Oct 25, 2017 05:55 AM
basketballus
Honda Civic (2001 - 2005)
May 28, 2009 12:13 PM
kobeballer96
Mar 31, 2009 10:15 AM
EvDog03
14
Jan 7, 2009 03:24 AM
tha Big EZ
Jul 17, 2003 08:40 PM
