88 hf bogs bad
ok got an 88 crx hf b18a1 obdo, heres the problem i can start the car and it idles fine, can rev it up to 6k fine, when i put it in gear and don't give it much gas it runs ok but as soon as i give it half throttle or more it bogs so bad that i have to put the pedal to the floor to keep it running. a little background the car has sat for 3 years with 1/4 tank of gas in it. i drained all the gas out of it and put three gallons of 93 in it with a bottle of injector cleaner. any ideas would be great
also not getting any codes!
yes it ran fine, i took the the fuel filter off yesterday and it was like sand in it can only think what the tank looks like,so i put another filter on it and still does the same, got some sea foam today and put it in the tank, going to try that. should i put the sea foam in then drain the tank, fill it again and drain etc ect ect?
ELAMINT5
Sep 9, 2005 07:28 PM
ironchef25
27
Feb 2, 2004 04:10 PM
