what possible consequences .. piston sticks out 0.075" at TDC .. h22 head
Old Sep 26, 2010 | 06:44 AM
street_ride14's Avatar
Default what possible consequences .. piston sticks out 0.075" at TDC .. h22 head
my particular setup ..
95mm stroke .. compression height = 1.220" .. rod length = 5.630" .. h23 block, h22 head, stock valves
what possible consequences will I run into with piston sticking out 0.075" at TDC ?
Old Sep 26, 2010 | 10:14 AM
jprelude92's Avatar
Default Re: what possible consequences .. piston sticks out 0.075" at TDC .. h22 head
the pistons on my h22 also stick out the deck but thats 'cuz all high compression pistons do that
Old Sep 26, 2010 | 10:21 AM
jprelude92's Avatar
put the head back on and put the timing belt on and turn the motor slow if the valves don't hit the pistos you should be ok
Old Sep 26, 2010 | 11:17 AM
q16racer's Avatar
so you are running h22 rods and h22 pistons coupled with an h23 crank? which h22 pistons are you using?
torque the head down and put cyl 1 to TDC; lock vtec into place and spin each cam over. If you feel it stop, do not try and keep going as you will bend a valve. measure clearance.
Old Sep 26, 2010 | 11:41 AM
yeah, Mahle 10:1 pistons with Eagle rods. Both for the H22 engine .. but ofcourse I want to use these with the H23 crank.
Old Sep 26, 2010 | 12:41 PM
q16racer's Avatar
10:1? was not aware they made a 10:1 piston. What is the dome volume?
Old Sep 26, 2010 | 01:17 PM
yeah, 10:1 .. Flat-top // -1cc valve relief volume
Old Sep 26, 2010 | 01:32 PM
q16racer's Avatar
you will need to clay the pistons as i said with vtec locked.
Old Sep 26, 2010 | 02:15 PM
will do, thanks for your help
Old Sep 27, 2010 | 09:55 AM
Originally Posted by PirateMcFred
Yep, you're running the wrong rods. I suspect that you'll have the pistons hit the head with a stock head gasket. Assuming that you have clearance for everything you'll be near 13:1CR too. It would all be much easier if you just used the proper rods.
thanks Pirate. Yeah 13:1CR is a little too much in this case, I'm trying to use this for a boosted application. I'll end up either using the H22 crank (and thus maintain the 10:1CR) or get a different rod to lower the CR and still use the H23 crank. Thanks for the help guys.
93h2beg
Jan 13, 2011 08:38 AM
schia89
Jan 3, 2011 04:13 PM
tonezilla
Feb 2, 2005 12:20 PM
yohan
Sep 23, 2004 11:39 PM
user 9782082308
Sep 7, 2003 09:40 AM
