Suspension & Brakes Theory, alignment, spring rates....
Need feedback for Subframe Problem.
Old Sep 25, 2010 | 11:35 PM
ixoiiiiviviiivi's Avatar
Default Need feedback for Subframe Problem.
The nut for the front lower control arm bolt in the subframe has broken off its welds and become stripped. It is rolling around inside the subframe basically. W/o having to change the subframe and/or hack the subframe into pieces is there a way to extract the stripped nut out and insert a new one? how would you go about fixing this problem? Where could I find a replacement nut?
Old Sep 26, 2010 | 09:17 AM
98civdx's Avatar
Master Detailer
Default Re: Need feedback for Subframe Problem.
Personaly I would replace it, its too easy to get another one, in most places.
The only im aware of getting it out is to cut a hole and get it out.
Old Sep 29, 2010 | 05:26 AM
B16Civic93's Avatar
this happened on my buddys hatch, he cut a small window out of the steel next to it and replaced the nut using a bent wrench to help tighten it. then welded a small steel plate back over the opening.
You should replace it though if you have the option. i've got a gsr subframe if interested lol
BradleBo
Nov 22, 2018 09:26 AM
mjf6866
Mar 21, 2013 07:04 PM
deschlong
Jun 24, 2012 11:27 AM
beanbag
Suspension & Brakes
Feb 11, 2009 06:04 AM
Magick211
Nov 23, 2001 04:52 AM
