Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Civic ES8 - Suspension problem
Old Sep 25, 2010 | 10:24 PM
GunSamir's Avatar
Default 2004 Civic ES8 - Suspension problem
Hello,
On my 2004 Civic, I hear a noise from the right front wheel when moving over a rough surface, sounds like a metal to metal touching noise. I was not sure if it is a bad dumper or something else. I went to see and here is what I found
Old Sep 26, 2010 | 02:41 PM
Pothole987's Avatar
Default Re: 2004 Civic ES8 - Suspension problem
you need to replace that bushing. its torn.
Old Sep 26, 2010 | 03:24 PM
jdmhondaes1's Avatar
Old Sep 26, 2010 | 11:45 PM
GunSamir's Avatar
Yes, I bought them all (2 for each side). I just did not have time to replace them.
Old Sep 27, 2010 | 04:32 AM
toyomatt84's Avatar
Sanji
Those compliance bushings are a common problem on the 7th Generation Civics.
Old Oct 21, 2010 | 01:05 PM
GunSamir's Avatar
The bushings have been changed. The noise has disappeared.
Old Oct 27, 2010 | 12:37 PM
Ehaz01DX's Avatar
I changed both as well due to a similar problem, but I still here some noise... Would lower ball joints be the problem? Although I was told my hub bearing needed to b replaced. N e thoughts???
Old Oct 27, 2010 | 07:19 PM
It Wasn't Me's Avatar
Is there noise coming from the bearing? Any grinding or wobbling? Can you wiggle the top of the wheel back and forth? Is there a roaring noise coming from the wheel, and does it get louder as you accelerate?
As far as the clunking/knocking noise - inspect the tie rod ends, ball joints, sway bar bushings and end links, etc. It should be relatively easy to find which component(s) needs to be replaced.
Leexx
Aug 11, 2006 12:46 AM
