******Apexi turbo kit - new pictures & price
Apexi P13 turbo kit + hks B series manifold + dsm injectors & more = $1,150
I took everything out of the boxes and oiled up turbo. MINT just like when I got it 7yrs ago. BB turbo still spinning effortlessly & ZERO shaft play.
Max power 260-280whp @ 14-16psi
WG spring set at 5.5psi and max is 14-16psi with stiffer gate spring
AC and PS friendly
Read more at https://honda-tech.com/forums/forced-induction-16/%2A%2A-apexi-b-series-turbo-kit-review-%2A%2A-713248/
Apexi turbo kit (to be used w/out FMIC) contains:
COMPLETE APEXI INSTRUCTION BOOKLET (18 pages with pictures) this was designed for anyone to be able to install it
IHI AX53B60-P18 ball-bearing turbo (t25 flanged)
5 bolt cast elbow down pipe
2" down pipe with o2 bung
o2 sensor extension & plugs (since it's not on the header but on collector)
turbo inlet metal gasket
turbo outlet metal gasket
manifold heat shield
(5) charge piping
Couplings & clamps
Heat resistant flex tubes (silver)
Apexi POWER intake filter (great design)
Apexi Twin Chamber BOV (adjustable for sound)
BOV block off plate (if you want to weld on another type of BOV onto the charge pipe)
Oil feed pipe & Oil return fitting
Oil lines
Oil hose clamps (4-5)
vacuum lines, t fittings & 3 way connectors
Nuts, washers, bolts, ect
Inline fuel pump
The only things NOT INCLUDED that came with the original Apexi kit is:
Apexi D series cast manifold
FMU
Roll of heat tape
zip-ties
Apexi metal decal
I will ALSO include:
- DSM 440cc injectors with resistor box
- HKS B series cast manifold
BNITB manifold long & short stud bolts, washers & nuts...(bought from OG Flamenco_T aka Stan when we first started his business in 03-04 Fast-Turbo.com
* I can include GSR, LS or D16a6 untapped oil pan for extra money.
History:
I bought this in 2003 and from honda-tech member in FL. It had only 3,000 miles and I had the member take it to a well known honda-tech member/tuner to inspect before shipping it to me.
Apexi released this kit for the D series in 2 forms:
a) turbo kit with out FMIC = $3200
b) turbo kit with Apexi Skyline FMIC & extra charge piping $3800
But it was way over priced compared to greddy kits 15G kits that were $2100 (no FMIC) & $2600 with FMIC. The kit is now discontinued. Over the past 7years I've only personally known & talked to 5 people who had this kit, & driven in 2 cars with this kit.
I sold the D manifold and sourced out a rare HKS B series cast manifold
If you think this turbo it too small for B series applications, think again.
Apexi made a B18c turbo kit with different manifold and same turbo in Japan, you can still order the kit online at Nopi & other import parts websites but it's $3,600
It make more power than greddy 15G kit, spools faster than greddy 18G kit but not as expensive.
Peiku made:
210whp & 185tq on stock d16z6 @ 10psi. (had zex cam only)
glagola1 made:
238whp and 226tq on stock LS 10psi
268whp and 247tq on stock LS 14psi
integlspwr2k made:
250whp and 175tq on stock b16a2 at 10psi
On a stock gsr it should make:
230whp & 175tq @ 7psi
265whp & 205tq @ 10psi
280whp & 220tq @ 14psi
turbo magazine review:
http://www.turbomagazine.com/tech/01...kit/index.html
(dynapack#)
171whp & 132tq @ 5.5psi on stock D16z6 (FMU & NO FMIC)
187whp & 141tq @ 5.5psi on stock D16z6 (FMU & with Apexi Skyline FMIC kit)
Full boost @ 10psi on D16 is 3900rpms
Full boost @ 10psi on B16 is 4200rpms
Full boost @ 10psi on LS is 2800rpms
I bought it for $1,350 shipped & HKS manifold for $250 shipped
old price was $900 shipped.... new price is $1,200 shipped
The only thing you need for this to work on your EG/EF/EK B or D series is:
1) EMS - crome free
2) I would ditch the inline fuel pump and get $79 walbro 255lph pump because they are not as noisy/annoying & you won't have to mount it in the engine bay like you would the inline pump.
3) sell the hks for $200 and get a Ebay cast Dseries T25 manifold for $100
(better design than greddy or apexi)
4) FMIC, ebay/mishimoto/godspeed/ect will work just fine $80-130 is more than enough for under 300whp
The rust is very light because my garage has humidity. I can be brush it off very easily. notice the top side got a little rust/ironoxide cause it's made of cast iron lol
but the bottom doesn't since the humidity can't "settle" on it.
Also notice the divided flange compared to Greddy Bseries cast manifold it's just all lumped up together.
How the Apexi D16 kit is advertised
Apexi GSR kit for sale in Japan
Notice same turbo, down pipe & cast elbow
AC and PS friendly
(5) charge piping
Couplings & clamps
Oil lines
Inline fuel pump
FMU
Roll of heat tape
zip-ties
Apexi metal decal
History:
Peiku made:
glagola1 made:
integlspwr2k made:
(dynapack#)
1) EMS - crome free
65 views & no free bump?
lol
yes sir.... those where the good old days before people could really learn how to tune will with hondata, crome, neptune, aem, ect...
Currently with just upgraded rods/piston on stock gsr sleeves I wouldn't hesitate to push 450whp all day long at the track. But hey, I consider myself pretty conservative.
If your looking for under 300whp
This kit will provide you the most power "under the curve" than any supercharge kit or turbo (t28, t3, 18G, 16G). The p13 powerband on a B18 is probably closest to a GT28 (not the GT2871RS)
lol
yeah but you also have to take into account the pros:
+ better than greddy 15g or 18g kit
+ only 3,000 miles
+ ac/ps friendly
+ already come with injectors & hks manifold (the kit did not include it)
+ mint & only missing FMIC & EMS to make it complete
+ New it sold for $3200 & i'm selling it with more items for a 1/3 of the cost... thats like buying skunk2 cams for $600 & reselling them for $200..(hell of a deal)
And the con:
- turbo only makes about 280-300whp at max
- the only cheaper kit that has this quailty is maybe a used Drag III kit
- you could make yourself a "home made kit" for about the same amount - but has no branding
+ only 3,000 miles
+ ac/ps friendly
And the con:
the cast elbo is bolted to the 5 blot exhaust side.
The HKS manifold vs. the Apexi D manifold are nearly idential, the hks actually sits a little taller therefore, the turbo would hang 3-5mm lower... but it's not any issue what so ever since this same kit was use on EG with B16 & LS with no modifyed to the down pipe or cast elbow.
so is it 1200 or 900 cause what you posted doesnt make sense.
you asking for 1200shipped as the new price but the old price was 900?
Sorry about that, I definatly understand your confusion on the price. My appologies. $1,200 shipped is the new price
Let me try and explain my thought process.
1)
I originally bought the kit because it was posted for $1,450 shipped. I offered him $1,350 and it sold in a matter of 4-5hrs on the FS thread he posted it. I jumped on it because I knew it was a killer deal. And now i'm passing on even a better deal to someone who wants to use it on their B series motors (hks manifold) for cheaper.
It went up because, In never really took every thing out of the box.
When i got it, I only inspected the turbo and that was it. It was inspected by a well recognized h-tech member and tuner in FL, he said everything was there and when I got, I didn't even lay it out to admire. I did sell the FMU right away. The HKS manifold I sold months later after I found one for sale here on honda-tech.
2)
Because of how complete it was and how great that p13 turbin spinned so smoothly, I felt that if I didn't get atleast $1,500. When I made my 1st thread, I totally forgot it came with inline fuel pump, extended o2 wiring harness, and the instructions. Not to mention I'm including DMS injectors & resitor box. I'd drept of having this kit on my GSR for the past 7yrs but after talking with TheShodan (off and on over the past 3yrs) he conviced me because I know more (cars/turbo/ect) now then I did back in 2003-2004, in a sense I've already outgrown 300whp applications. I waited too long to use it and now 280-300whp just seems too low for me. Not sure if that makes sense or not. But I totally agree.
3) If I didn't get $1,150 for the kit, it would not be worth it for me to part ways with it.
I could probably just slap on the turbo kit, tune it and post up dyno charge and the kit would sell with much less effort.
4)
You know what I mean by that feeling of passing something on & never have used it?
I'm sure if I used it I wouldn't mind letting it go for cheaper. But hey, I guess I had a change of heart after I cleaned up everything & laid out the complete kit. Haha and the instruction booklet was pricless... 18 pages of how to install every little nipple, bolt & gasket...
5)
Show me a minter greddy 18G kit & as complete for this price and I'll match it.
This turbo is good up to nearly 280whp. 18G are good up to 350whp ma. I don't compare it to the Greddy 15G kit because the most power i've seen on that tiny blower on a LS motor was 230whp & that's with the internal WG welded and using a different manifold with a external WG with the turbo screaming for it's dear life @ 17psi That's why I said in my thread:
"smaller & faster spool than 15G & not as expensive as the 18G."
All I can do it tell you as much as I know about the kit and what my plans are/were.
If you want it, Great! if not I completely understand.
Charlie Moua
1)
2)
4)
5)
Charlie Moua
ok thanks for clearing things up
just wanted to make sure how much it is. its a little out of my price range right now. but free bumps
imlachg1
Jan 18, 2004 02:09 PM
