wheel spacer and OEM studs safe?
Old Sep 25, 2010 | 11:25 AM
gosu08's Avatar
Default wheel spacer and OEM studs safe?
I might have to get wheel spacers if I cannot find a pair of front wheels to clear my calipers.
It would be a 8mm spacer.
My question is how safe is it to run a 500+hp with a 8mm spacer without extended studs?
Is it ok?
Old Sep 25, 2010 | 11:47 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: wheel spacer and OEM studs safe?
Max people run is about a 2-3mm spacer. Anything over that is asking for a wreck.
Old Sep 25, 2010 | 12:07 PM
gosu08's Avatar
I have to clear spoon calipers thats why.
I am having the hardest time finding 2 rims that clear the spoon calipers.
I have found some but they are just too expensive (SSR, Volks). Im looking to get kosei k1 in +38 offset but no luck finding any...
Old Sep 26, 2010 | 08:43 AM
nsxtasy's Avatar
H-T Order of Merit
Is it ok?
You need at least 6.5-7.0 full turns on the lug nuts to be safe. If you don't have that much, then you'll need extended studs.
Old Sep 26, 2010 | 08:31 PM
gosu08's Avatar
thank you. i will do spacers first and see if i can safely turn them the amount that you listed and if not....more rim searching
Old Sep 30, 2010 | 12:05 PM
ej1 rep's Avatar
dude just get extended studs
jdmspoonitr
26
Nov 4, 2015 01:15 PM
gosu08
Jun 16, 2012 11:10 AM
EJ2B16
Nov 25, 2011 09:05 AM
Midori Green
15
Jan 1, 2008 10:39 PM
Scorpaznatica
Apr 20, 2002 10:40 PM
