Clutch Really Soft on my 93 civic
Old Sep 24, 2010 | 08:21 PM
Mylinh's Avatar
Icon3 Clutch Really Soft on my 93 civic
Hi guys so i just bought a car earlier this month and it drives perfect but recently my clutch is extra soft and hardly any resistance. It catches gear fine doesn't seem to slip but the clutch is REALLY soft and it wasn't like that before... Is it possible to fix this problem myself? Any opinions or help much appreciated
Old Sep 24, 2010 | 08:22 PM
melsers's Avatar
Default Re: Clutch Really Soft on my 93 civic
try bleeding it?
Old Sep 24, 2010 | 08:35 PM
Former User's Avatar
Is the fluid level low in the reservoir? Any visible leaks from the slave cylinder or master cylinder in the engine bay or from above the clutch pedal?
Old Sep 25, 2010 | 07:26 AM
Mylinh's Avatar
ok i will try this out thanks!
Old Sep 25, 2010 | 07:31 AM
green97coupe's Avatar
if you have to pump your clutch pedal up to work properly its your slave cylinder if not then, you have either a leak some where or it needs to be bleed.
Old Sep 25, 2010 | 09:04 AM
fv8s's Avatar
it can be a few things like everyone stated above.
- low fluid
- bad slave cylinder (located on your transmission)
- leak in the line
- bad master cylinder
all of these are easy fixes. have a friend stand outside while pulling away the black dust boot covering the slave cylinder. you can sit inside and push the clutch pedal while he watches the travel of the slave cylinder. if that is not it then start going down the list until you figure it out
Old Sep 25, 2010 | 04:11 PM
Mylinh's Avatar
alright thanks for all the replies i am going to try out the slave cylinder and ill let u guys know what happen
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
dgerej2
Oct 1, 2009 07:16 AM
crxricer66
Dec 1, 2007 07:58 PM
RaceMyGhost
Dec 26, 2005 09:51 PM
SloCivicHMM
May 12, 2003 01:57 PM
