96 Accord possible transmission prob
Old Sep 24, 2010 | 07:56 PM
JUSTINTHECOASTI's Avatar
Default 96 Accord possible transmission prob
heys, I'm mostly in the s2000 forums than anything because mine is my toy, however today I need help with my DD. its an auto 96 accord that recently developed a problem, when in drive(D4) or park, the green square begins to blink but only around D4, also I gettin alittle sputter and mild hesitation, I was wondering if anyone had this problem and kinda knows what it is...thanks guys
Old Sep 24, 2010 | 08:01 PM
redbull-1's Avatar
Default Re: 96 Accord possible transmission prob
See this link for information. Although your car is OBD-II, it still has the service check connector under the passenger side dash. Jump the connector with a small paper clip or wire and read the transmission trouble code. The link includes most of the info.:
http://techauto.awardspace.com/transmission.html
Old Sep 25, 2010 | 08:07 AM
thank you i'll let you know results
Old Sep 25, 2010 | 08:39 AM
also where is the port where I'd pull a CEL code? I just got a the light as well thank you
Old Sep 25, 2010 | 08:50 AM
redbull-1's Avatar
Your OBD-II port is behind the ash tray. However, the other port is under the passenger side dash. (Most 96-97 Accords should still have this.) Look underneath the passenger side, you should see a blue plug connector. It is the two prong one. You may have to unplug it and then jump it.
Old Sep 25, 2010 | 09:06 AM
ok thanks
stanced96
Nov 9, 2014 09:55 AM
lv6l
Aug 14, 2012 12:02 PM
WorknProgress
Sep 16, 2011 03:26 AM
rookshot06
Jun 20, 2010 11:47 PM
