Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
replace my old sphericals? FROMWHERE!
Old Sep 24, 2010 | 05:57 PM
redzcstandardhatch's Avatar
something different
Default replace my old sphericals? FROMWHERE!
years ago (like, 7 or 8) i bought ITR rear lower control arms from some dude on here. they has spherical ball bearing setups in them, brand new
now they are shot to all hell. thousands of track miles, and street miles, and they suck.
do i need dimensions of them (ID of the sleeve, thickness, monoball-size,etc), or does somebody make a setup for ITR -sized bushings?
anybody know?
Old Sep 24, 2010 | 08:46 PM
KIWI's Avatar
Default Re: replace my old sphericals? FROMWHERE!
Call me, I have replacement Hardrace Hard Rubber bushings that should fit.
Do you have the Type R Pressed Steel rear LCA's? If you use the car on the street you really don't need Sphericals.
Kiwi
Old Sep 24, 2010 | 08:52 PM
topdog's Avatar
I'm working on the same situation but on my rear camber arm. Looking to replace them with Aurora bearing ( http://www.aurorabearing.com/ ). Basically you will need the OD of bearing and ID diameter that fits into the sleeve if used. ID for the bolt that will go through it. If possible look to see if the bearing being replace will have a zerk grease fitting which will help keeping grease inside and keep the bearing lasting a longer.
Old Sep 24, 2010 | 11:23 PM
NAEGH22's Avatar
Kiwi - have you supplied anyone with a set of sphericals to suit ITR rear LCA's before?
anyone else found a replacement for the ITR rear LCA bushes?
Old Sep 25, 2010 | 03:41 AM
something different
Kiwi
i mainly bought the LCAs years ago because they were a good deal (yeah, they are the pressed steel Rear LCAs), and i needed type R or 88 CRX lcas with the konis i had.
while i spend a lot more time in the car on track, i do a thousand or more miles a year on the street, and run errands in it when its nice out. i'll never take it completely off the street, thats kind of a personal goal.
i think the dude i bought these from might have been you kiwi...not sure. did you sell these years ago? this was when i first joined HT
Old Sep 25, 2010 | 06:32 AM
wEaK Squad *ATL*'s Avatar
Get wicked tuning control arms!
Old Sep 25, 2010 | 04:29 PM
SPiFF's Avatar
Drop Chris at Kingpin Machine an email.
cbrinson~~at~~hondaprelude~~dot~~com
Old Sep 26, 2010 | 04:36 AM
Stinkycheezmonky's Avatar
Suspetise...
Adam, that PM I sent you, Chris B. is the guy I was thinking of. Thanks for posting that, Zsolt.
solex
Honda Civic (2001 - 2005)
Mar 24, 2017 10:58 AM
maxogsr
Jun 11, 2016 02:40 PM
eg:R
10
Oct 15, 2011 02:15 PM
Ekasey
121
Jul 20, 2009 01:17 PM
Old_Honda
Jul 20, 2005 09:27 PM
