Golden eagle Intake mani for B16 / Type r
If Your Search For a Dependable Engine Block Has
Lead You To a Dead End G.E.. IS HERE TO HELP YOU.
Performance and value made in the USA.
Generating extra cubes via G.E. big bore sleeves is a good
solid technique to gain more lbs.ft. even if nothing else is
done to the engine.
G.E. STROKER STRATEGIES FOR HIGHER HORSEPOWER
Add a stroker kit to the mix and get an even better increase
of power.
For over a decade G.E. has focused on supplying the
professional engine builder and back yard mechanic with
the best performance products in the business at a price
that is affordable. G.E. is focused on being on the cutting edge
of engine and part development.
The next time you build your engine use G.E. sleeves and products.
