Squealing sound when ac is turned on at low rpms (01 Civic LX)
I'm not sure what is causing the squealing, but as soon as I turn my AC on and my car is running at low rpm's the car will squeal unless I am in 4th or 5th gear at higher rpm's. What I find wierd is that when I press the clutch in the squealing noise goes away, but if I release the clutch at a low RPM the squealing will continue. Also their is a wierd burn smell kinda like burning rubber or like a vacuum cleaner being burned out kinda smell for a few seconds and it goes away. Does anyone know what could cause this or what the problem is? Any help is greatly appreciated.
wickedmaniac
12
Jun 6, 2014 08:18 AM
