****HONDA CRX SI PROFESSIONALS*****
Old Sep 24, 2010 | 06:23 AM
slkrik72's Avatar
Default ****HONDA CRX SI PROFESSIONALS*****
WOULD ANYONE KNOW HOW TO STOP THE DOOR LIGHT AND SEAT BELT LIGHT FROM TURNING OFF AND ON ALL DAY?
Old Sep 24, 2010 | 06:26 AM
91c-rex_si's Avatar
Default Re: ****HONDA CRX SI PROFESSIONALS*****
seat belt light you just unplug the wires directly underneath the carpet of the seats. door light im not to sure about
Old Sep 24, 2010 | 09:51 AM
CRXguy_88's Avatar
I think the title needs to be changed but.. I have the same problem but my driver side connection is not connectedthe connector on the chasis end was cut so I can't Plug it in. The pass side is plugged in and I disconnected the plug by the rear view miror so the door opening won't beep and light won't flash but the light on the cluster for the seat belt just flashes all the time how do I get that to stop? It been like that for about three years now
Old Sep 24, 2010 | 11:23 AM
rustbucketrex's Avatar
Until I fixed my seat belt I just removed the light in the cluster behind the seat belt icon. Short term fix for the light only. You need to fix the belt issue that is making the light blink though.
Old Sep 24, 2010 | 12:06 PM
freydaddy's Avatar
the door light coming on and off might be due to the switch on the jamb. Try to adjust it.
Old Sep 24, 2010 | 07:13 PM
Bob_760's Avatar
You probably need to clean/sand the contacts on your door switch. If you take the door switch out it's pretty easy to see how it works.
vroomboom
Honda Civic (2001 - 2005)
Jun 3, 2008 12:31 PM
WindyCity
Jul 6, 2006 12:12 PM
SexyAzNMami
Nov 16, 2004 06:49 PM
Cone
May 27, 2003 03:32 PM
