Initial cam degree recomendatations M24X
Old Sep 24, 2010 | 06:10 AM
blundar's Avatar
Default Initial cam degree recomendatations M24X
I picked up a set of M24X cams from Don@DFE last year (year before?) and finally got around to using them. In the meantime, I lost Don's notes on initial cam degree specs. I'd prefer to degree off the low cam lobes but I can lock the vtec lobes if need be - engine is on a stand. Have a Belben degree fixture.
Engine is a RS piston 84.5x89 if that matters, GSR head, S2Pro series IM, 68mm body.
Thanks
-Dave
Old Sep 24, 2010 | 08:28 AM
DDTECH's Avatar
Default Re: Initial cam degree recomendatations M24X
Thanks
-Dave
editing for future searches** The cam gears settings were wrong, after confirming with donf - , i was meaning to post numbers not cam gear settings slowsleeper was correct, donf has done them around 100/101 and 106ish
the vtec lobes / primaries share the same center lines.
Old Sep 24, 2010 | 09:48 AM
slowsleeper's Avatar
depending on what you have for valve-to-valve clearance, degree them to 101/106 on the VTEC lobes of course.
Old Sep 26, 2010 | 12:45 PM
blundar's Avatar
for posterity:
slowsleeper got it right.
101/106 centerlines. According to Rocket, the small lobe has the same centerlines as the big lobe.
Old Sep 26, 2010 | 05:24 PM
egb18c5's Avatar
thanks for the info for future reference
EGunit
Aug 5, 2007 11:23 PM
NaIsGay
Feb 4, 2006 09:50 PM
Reis
Jul 20, 2005 02:44 PM
cadougherty_67
Mar 6, 2005 06:11 AM
