*** S2kjay build thread PG+K ***
Old Sep 24, 2010 | 05:59 AM
smR_lsvtec's Avatar
Default *** S2kjay build thread PG+K ***
Well it's time to ditch the boost and go NA. Gotta get my car ready for some track events in the near future. I'll be doing a very mild built on the motor since Ill be using it for street/track. Still awaiting on a race header, oil pan, valve train, pistons and some R compounds.
Picked u a set of TWM 52mm ITB's
test fitting the itb's before tearing the motor down.
update!
So after pulling the motor out and taken a look at the internals we found out that i had some piston rings break on me and it messed one of the cylinder wall up pretty bad.
Took the block up to my machine guy to have him look at it and come to find out that the scars are too bad to bored out. So we decide to go with re-sleeving it instead of buying a new block. I should have the block back by Monday. :alkie:
While the motor was out we took all the ABS stuff out and installed a booster delete and new Wilwood brake master cylinder and proportional valve.
Still gotta clean up the wiring
Old Sep 24, 2010 | 06:12 AM
Accord2Show's Avatar
Default Re: *** S2kjay build thread PG+K ***
Looking go so far, good luck with the build.
Old Sep 24, 2010 | 08:43 AM
mattrt09's Avatar
lookin good man coming along great
Old Sep 24, 2010 | 12:50 PM
inzanejdm's Avatar
looks good any plans for the rebuild?
Machinehead115
Oct 22, 2007 10:39 AM
Javier
Jul 13, 2004 08:58 AM
BlendedEJ8
14
Jun 25, 2003 10:02 AM
Plan B
50
Jan 7, 2003 11:33 AM
Plan B
Jan 6, 2003 09:28 AM
