Just finished ls swap in 97 civic...need help!!! Runs like shiit
well guys i just finish my swap (96 b18b1 in a 97 civic) and when i went to start the car up it starts,but then it losses power for sum reason...no matter how much i gas it,it jus stutters and wont go no where..
You also need to depin a wire and place it in a diff location on the ecu plug, well only if you car didn't come with a normal style intake manifold,
ryte now im using an obd2 ls ecu that came with the motor...which i dont think it matters kuz arent obd2 civic non vtec ecu almost the same as obd2 ls ecu which are both p-75??also i tried running it with a obd2-obd1 harness n obd1 ecu but still actin the same..
civics never came with a p-75. only the Integra ls, rs came with a p75
try a different ecu. if that fails test the compression and start looking for vaccum leaks. take pictures or a video for us to show what it looks like and how it runs. there could be 20+ things causing this problem
ok soo before i got to to solve this problem,no the car wont start at all...i went to start it today and it started up for a couple minutes until i gas it a lil it jus stutters and die and now it wont start back up..i tried switchn up the tps n map sensor and still wont start..
