Timing belt tensioner
Old Sep 23, 2010 | 11:15 AM
2k.civic.si's Avatar
Icon2 Timing belt tensioner
How many of you have used or run one of these?
endyn also has their own version of it but i dont like it as much
Old Sep 23, 2010 | 12:49 PM
Default Re: Timing belt tensioner
no one has used one?
Old Sep 23, 2010 | 06:05 PM
tales sol's Avatar
ive thought about using one if that counts? :D
i hate that whip off that side of the belt, freaks me out!
why dont you like the endyn one? i was thinking of making one up!
Old Sep 24, 2010 | 10:01 AM
The block mounting points the other one uses are a stronger place to bolt to.
Old Sep 24, 2010 | 11:40 PM
FlewByU352's Avatar
I can honestly say this is a 1st for me seeing this type of tensioner. Are they still using the stock tensioner and adjusting this to put the same tension as a backup? Or are they eliminating the stock tensioner? Also looks like the mounting will be in the location for the power steering pump.
Old Sep 25, 2010 | 01:46 AM
95skunkedgsr's Avatar
i rememeber reading a thread somewhere you gotta becarefull using it < think someone broke there exh cam or something have to see if i can find it
Old Sep 25, 2010 | 08:09 AM
Same thing can happen to the intake side when people over tighten the belt with the stock tensioner.
This is just supposed to barely put enough pressure on the belt to keep it from jumping all over the place at high rpm....kinda like the skunk2 one for the k series.
somick
Feb 18, 2017 10:40 AM
slide inside
Oct 22, 2009 09:25 AM
ShortyzKustomz
Jan 12, 2008 09:56 AM
mattatchison
Jun 7, 2007 04:58 PM
eddiecut
Jun 16, 2003 12:10 PM
