Suspension & Brakes Theory, alignment, spring rates....
traction bar question
Old Sep 23, 2010 | 08:18 AM
jaydmdude's Avatar
Default traction bar question
I posted this in the CRX forum but received nothing. So maybe you guys can help me out.
I was looking at the full race bar, etd bar, innovate bar and I've noticed that they all have
a bracket(minus the innovate) for the LCAs so that there can be 2 bolts to screw into
both of holes in the LCAs. I've recently bought an avid pro bar setup from IPG performance
and I noticed that the bar didn't come with this bracket. I installed the bar by the
instructions and the heim joint at the lca is only bolted into the closer hole toward the
front of the engine. I was just wondering if this will affect drive-ability at all? Should I be
concern with the heim joint being bolted up to one hole at the LCA instead of having a
bracket to bolt into two of the holes? It'll be great to hear from the Avid pro bar users.
any input is appreciated.
Old Sep 23, 2010 | 08:46 AM
phunhaus's Avatar
Default Re: traction bar question
Nothing to worry about. If you're serious about dragging the car look into KTuned's "stabilizier bars" which are traction bars for the rear hole to the chassis.
tauumie
25
Jun 15, 2011 12:25 PM
94sohcVTEC
May 31, 2005 12:30 PM
rodimus
Jul 30, 2002 10:08 PM
