Alignment of dropped cars.....
Old Sep 18, 2002 | 11:35 PM
armharm's Avatar
Default Alignment of dropped cars.....
ok... this is the thing..... i have a very irregular wear on my tires, they're almost down to the metal on the inside and its obviously because of my alignment..... anyways, i have H&R racing springs and stock shocks.... i took it to several places and they refuse to align it because its dropped... what should i do???
Old Sep 19, 2002 | 06:17 AM
dcb0821's Avatar
Default Re: Alignment of dropped cars..... (armharm)
You will probably need to get a camber correction kit, install that and then get an alignment, that should bring you back to spec. As far as no one wanting to do the alignment you are going to wrong places I guess...
Old Sep 19, 2002 | 08:45 AM
armharm's Avatar
Default Re: Alignment of dropped cars..... (slowlude)
why though? there are a shitload of mechanics here and there who will do it but dont offer warranty, but sears for example refuses to do it.....
Old Sep 19, 2002 | 05:24 PM
user 9782082308's Avatar
You can't adjust camber on alot of Hondas. On a stock suspesioned car, if camber is off they actually have to bend some part of it. My guess is the spindle. Anyway, the only correct way to fix the camber on your car would be to get a kit.
Old Sep 19, 2002 | 05:42 PM
Cottonwoodz's Avatar
If you can find a good camber kit for a 4th gen, let me know.
Old Sep 20, 2002 | 02:27 PM
Unreasonable's Avatar
I ran into this problem recently at NTB - Conversation was something like "we can't do it because it's too low" "... why." "we can't get it onto the rack because the front lip is hitting it." Apparently "normal" garages don't want to fool with the xtra work of getting a low car on there and fear getting sued thinking they could break your car. some speed shops can do it but they wana charge a ton too
Old Sep 20, 2002 | 03:31 PM
rybred's Avatar
there are places that will do it, i ran into the same problem, most places will not do it, i took it to a place that deals with frames and steering, and they do it no problem, very few places do, u can try some performance shops in your areas, the good ones might have some laser alignment..later!
Old Sep 20, 2002 | 04:30 PM
jc836's Avatar
Let's get this right. Any alignment shop with a newer Laser alignment machine CAN do a dropped Honda. Some shops still have a pit type of alignment machine and the talent to do it too. I agree that you need to find a shop that understands lowered cars. My Honda dealer uses a Beam Visualigner Laser based machine and does my cars routinely. I've also had my Prelude aligned at a local Pep Boys on a similar machine.
As to Camber kits: Both Ingalls and Specialty Products make them for 5th gen and 4th gen Preludes. The exception is the front of an SH. For those there is an alternate front kit supplier at http://www.northstarmfg.com. I'm using Ingalls in the rear and Specialty up front. 4th gen owners can use the same type of kit on both ends from either maker as the control arm mounting is very different between 4th and 5th gen cars.
You CANNOT just buy a kit-you must have an alignment first to find out how far out of spec you are. Then you can look up the parts (or call) you need. I get my parts from Ultra Performance in Tucson/ but there are others that sell these brands.
Happy Luding
Old Sep 20, 2002 | 04:55 PM
99_SH's Avatar
You're problem is that the alignment shops in glendale are ghetto. The closest place to you, there's a in La crescenta, Winston Tires. They did my SH there, and its dropped 1.4"
There's this one place in Anaheim, Wheel Warehouse. I go there, cause they do a good job, and dont scratch my wheels.
Old Sep 21, 2002 | 07:24 AM
stoopid215's Avatar
Default Re: Alignment of dropped cars..... (99_SH)
I live like 10 minutes from there, wheel warehouse tried to charge me $176 for one RE92!!!!
Old Sep 21, 2002 | 08:02 AM
RAB's Avatar
RAB
Ok this is why you have irregular tire ware. Its due mainly becuase of your irregualr look of your lower control arm. When your car is stock your lower control arm has the look of the lower pic, when you lower your car dramatically with Race springs your lower control arm will look like the middle one. And Finally my lower control looks like the one on top. CAMBER KIT is only solution
Oh and BTW you might want to get after mrk shocks pretty soon.
krazyteg
Suspension & Brakes
Feb 18, 2006 05:34 PM
hOndafienD 04
Oct 17, 2004 06:42 AM
GUNNER666
Jul 28, 2004 08:26 AM
dom93hatch
Apr 19, 2003 10:26 PM
mps9506
Oct 2, 2001 03:47 PM
