94 prelude, jdm h22 partout
parting out my prelude it has a jdm h22 and a recently spun a rod bearing bottom end and trans have around 60k miles
i just rebuilt the head it came back from the machine shop 9-7-2010 have reciepts it has about 150 miles since rebuild
the head was hot tanked and milled .012, supertech valve guides and seals were installed, 3 angle valve job, valve seats were cut and new skunk2 pro series valve springs and skunk2 high compression valves were installed
also has arp head studs, new water pump, timing belt, and manual timing belt conversion all have about 150 miles on
other aftermarket... skunk2 cam gears, modified dc header w/ 2.5" collector,aem cai, p72 ecu w/ h22 map burned on it, apexi vafc2, exedy stage 1 clutch-about 10k miles on it..black housing halo headlights, lowering springs (unknown brand were on when i bought it along with red unkown adjustable struts in front and kyb gr2's in rear)
body is decent except for driver rear quarter, car is in primer originally red
has 17" nissan sentra ser spec v wheels painted black with honda center caps
interior is complete and nice condition..minus the cup holder
i want everything gone
pics will be uploaded shortly
Last call before it goes to eBay!!! on the complete spanky new cylinder head loaded with the sk2 parts with all sensors valve cover and vtec solenoid
$600 plus shipping.... Its a steal I have over $1200 into this head with only 150 miles on it!!!!!
Id rather see it go to a Honda-tech member
