just got it to run, help!
Old Sep 22, 2010 | 03:03 PM
89civicsiowner's Avatar
Default just got it to run, help!
so i finaly got my d15b vtec to fire but it runs really rough and barely at all the firing order seems right but i did just swap the guts to my dizzy if i messed it up would it run at all? anybody have any ideas?
Old Sep 22, 2010 | 03:16 PM
Default Re: just got it to run, help!
i have spark to all cylinders by the way
Old Sep 22, 2010 | 05:23 PM
only codes are 21,22 vtec not hooked up seems to be running on 1 or 2 cylindersanybody have a clue.....please?
Old Sep 22, 2010 | 05:30 PM
Oedwards's Avatar
Do you have a timing light?
Old Sep 22, 2010 | 05:32 PM
not at the moment i can tomorow
Old Sep 23, 2010 | 08:44 AM
could this be a ground issue?
Old Sep 23, 2010 | 09:03 AM
white90crxhf's Avatar
it doesnt sound like a ground issue, i don't think it will run if it's not grounded.
The firing order seems right? better find a diagram to make sure, when i had my firing order off it ran but really rough.
Old Sep 23, 2010 | 09:06 AM
julioboostamante's Avatar
check your timing belt, spark plug wires, ECU wiring, Etc. anything that was modified.
Did you do the DPFI to MPFI swap yourself?
Old Sep 23, 2010 | 09:21 AM
it was an si, and ive got power to all injectors, all plugs spark, im getting a buddy to run his timing light over but if anyone has any other ideas im open to suggestions, im gunna look real close at all my wiring
Old Sep 23, 2010 | 10:07 AM
JCRXTURBO20916's Avatar
What ecu are you running, and did you remove you resisor box to you injector.
Old Sep 23, 2010 | 12:58 PM
aha got it wire got cut during the swap, but im still only running on 3 cylinders, next question how do you tell if an injector is firing? they have voltage
Old Sep 23, 2010 | 01:33 PM
p28 virgin and yes no resistor by the way
Old Sep 23, 2010 | 02:29 PM
91ef9king's Avatar
put a screw driver on the injector put it to ur ear u should hear a clickin noise from each, when u did the multi point conversion did u connect both yellow/black wires from the dual ponit primary and secondary injectors together?
Old Sep 23, 2010 | 03:15 PM
it was an si mpfi, so my number three injector doesnt work but its getting power wtf?
"goose"jay
13
Mar 13, 2011 05:57 AM
rustanghunter
Nov 13, 2010 01:23 PM
efjones9
May 14, 2009 08:45 PM
blake22
Jan 8, 2009 01:17 PM
-DC2-
Mar 22, 2004 08:49 AM
